ObjectARX
IPropertyManager example
6 REPLIES 6
651 Views, 6 Replies
I've been looking around for examples of using the IPropertyManager
to retrieve custom properties from entities, but can't seem to
find any. Can anyone help?
Steve
6 REPLIES 6
Hi Steve,
here's a sample for the creation of Properties with the help of
IPropertyManager. The property manager acts as a container for your dynamic
properties and handles them.
You can create your dynamic properties with the objarx wizard, which creates
a propertyadmin, which you don't need explicitly. What I did was to use the
wizard to get proper properties classes, delete the admin and handle the
dynprops within my custom objects like in the sample. I encountered a
problem of Acad by trying to use dynamic props for custom classes directly.
Here you have to use custom object COM wrappers otherwise acopm will get
confused and mixes up the properties of different classes.
Hope to help
Joerg
Sample code:
long CMyClass::setProps()
CComPtr mm_pPropMan;
XLinieProperty *mm_newProp = NULL; //My dynamic property
long mm_ct = -1;
mm_pPropMan = GET_OPMPROPERTY_MANAGER(this->isA());
if (mm_pPropMan != NULL)
mm_pPropMan->GetDynamicPropertyCount(&mm_ct);
//create only if not already done...
if (0 != mm_ct) return mm_ct;
//Create a custom dynamic property
if SUCCEEDED( XLinieProperty::CreateInstance( &mm_newProp ))
mm_newProp->AddRef();
//Fill up the attributes of the dynamic property (depends on your
implementation of your dynprop)
mm_newProp->SetCategory("Line-Props");
mm_newProp->SetCategoryId( 0 );
mm_newProp->SetCaption("Name");
mm_newProp->setNumber(-1);
mm_newProp->SetEditable(true);
mm_newProp->setType(VT_BSTR);
//add it to the propman
_com_util::CheckError(mm_pPropMan->AddProperty( mm_newProp ));
mm_ct++;
return mm_ct;
Steve Van Ausdall schrieb in im Newsbeitrag:
51994ABFC0E0D3976839D08732916C16@in.WebX.maYIadrTaRb...
> Hi,
> Thanks,
> Steve
Thanks, Joerg!
I'm actually trying to get properties from entities that someone else wrote.
The property I want does show up in the property panel. Is there some other
way to get values to appear there? Could you see if I'm doing something
stupid? I have the following so far - but mm_ct is always set to 0.
#include
AcDbEntity *pEnt;
AcDbObjectId oObjId;
IPropertyManager *mm_pPropMan;
acdbOpenObject(pEnt, oObjId, AcDb::kForRead);
mm_pPropMan = GET_OPMPROPERTY_MANAGER(pEnt->isA());
Thanks again,
Steve
"J. Schlingheider" wrote in message
news:D5A247625F8C842C878B951F458479BD@in.WebX.maYIadrTaRb...
> Hi Steve,
dynamic
creates
the
directly.
> Hope to help
> Joerg
> Sample code:
> long mm_ct = -1;
> mm_ct++;
> return mm_ct;
> > Hi,
> > Thanks,
> > Steve
No, its's perfectly straight! mm_ct=0 means that there are none dynamic
props! But remember, not all props shown in the props dialog are dynamic
props. I suppose that those props shown are static properties, which come
from the COM-object wrapper. If you have a look at the typelib of your dbx,
and look out for the interface of the custom entity, then you'll probably
see the props (propput,propget) you see in your props dialog, Those
properties are managed by acopm directly. The way the values you enter are
assigned to the entity depend on the implemetation within the COM-coclass.
To change that won't be very easy, one way could be to create a new entity
which inherits from the existent one, but therefore you'd have to have the
header files. Another way would be to implement the com-interface in another
coclass, and try to make acopm use your coclass when accessing the entity
(by using the same GUID), but in that case you also have to know something
about the custom entity... so not an easy thing to do.
Regards, Joerg
wrote.
other
> #include
> AcDbEntity *pEnt;
> Thanks again,
> Steve
> > Hi Steve,
> dynamic
> creates
> the
> directly.
> > Hope to help
> > Joerg
> > Sample code:
property
> > long mm_ct = -1;
your
> > mm_ct++;
> > return mm_ct;
> > > Hi,
> > > Thanks,
> > > Steve
Happy New Year!
Thanks for your help on this - I really appreciate it.
I don't want to change anything or create new entities. All I want to do is
read the properties of objects that I don't have the source code for.
(Like the property window reads them) I don't even know if there is
a dbx... Is there an easy way to simply read them? Do you have code?
Would it involve QueryInterface? Is that an MFC thing?
Thanks again!
Steve
news:99E318FF853D44B376967FA11579F4E2@in.WebX.maYIadrTaRb...
dbx,
another
> Regards, Joerg
> wrote.
> other
> > #include
> > AcDbEntity *pEnt;
> > Thanks again,
> > Steve
> > > Hi Steve,
> > dynamic
> > creates
use
> > the
the
> > directly.
get
> > > Hope to help
> > > Joerg
> > > Sample code:
> property
> > > long mm_ct = -1;
> your
> > > mm_ct++;
> > > return mm_ct;
> > > > Hi,
> > > > Thanks,
> > > > Steve
Hi Steve,
happy new year to you as well!!
From which point do you want to read the properties? From a selected object,
when iterating through the database, from VB, ....? If you want to get
properties via the acopm mechanism you would have to use COM to achieve that. If
you have your object opened via the IAcadEntity-Interface, you have to use
QueryInterface in order to get the props of the custom object, you are quite
right here. Unfortunately I have no code for that problem ready at hand, but
someone else might have.
Joerg
Steve Van Ausdall schrieb:
> Happy New Year!
> Thanks again!
> Steve
> dbx,
> another
> > Regards, Joerg
> > wrote.
> > other
> > > #include
> > > AcDbEntity *pEnt;
> > > Thanks again,
> > > Steve
> > > > Hi Steve,
> > > dynamic
> > > creates
> use
> > > the
> the
> > > directly.
> get
> > > > Hope to help
> > > > Joerg
> > > > Sample code:
> > property
> > > > long mm_ct = -1;
> > your
> > > > mm_ct++;
> > > > return mm_ct;
> > > > > Hi,
> > > > > Thanks,
> > > > > Steve
I want to read them while iterating through the database, in C++ (ARX) -
Thanks again for the help! - Steve
news:3C3439DC.FD2E61D8@web.de...
> Hi Steve,
object,
that. If
quite
but
> Regards,
> Joerg
> > Happy New Year!
is
> > Thanks again!
> > Steve
dynamic
dynamic
come
> > dbx,
probably
are
COM-coclass.
entity
the
> > another
entity
something
> > > Regards, Joerg
else
> > > wrote.
some
> > > other
something
> > > > #include
> > > > AcDbEntity *pEnt;
> > > > Thanks again,
> > > > Steve
> > > > > Hi Steve,
your
> > > > dynamic
which
> > > > creates
to
> > use
> > > > the
handle
> > the
encountered a
> > > > directly.
will
> > get
> > > > > Hope to help
> > > > > Joerg
> > > > > Sample code:
> > > property
> > > > > long mm_ct = -1;
on
> > > your
mm_newProp ));
> > > > > mm_ct++;
> > > > > return mm_ct;
Newsbeitrag:
> > > > > > Hi,
IPropertyManager
> > > > > > Thanks,
> > > > > > Steve
”Boost
