ObjectARX
How to focus back to CAD?
2 REPLIES 2
D_D_K
355 Views, 2 Replies
I use this code to create modeless dialog:
w= new Dialog(CWnd::FromHandle(adsw_acadDocWnd());
Normally when the dialog closed, then the focus is set back to Cad.
However, on Cad25 it seems not to return. If I use Setfocus, the screen flickers occasionally.
Even in debugging, after closing, it will navigate to another window (chrome, vs,..).
Is there any way to fix this?
2 REPLIES 2
daniel_cadext
in reply to: D_D_K
If it’s modeless, shouldn’t the owner be the main frame, or adsw_acadMainWnd?
Are you handling WM_ACAD_KEEPFOCUS?
I don’t know the answer, just things I would look at
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
D_D_K
in reply to: daniel_cadext
Hi @daniel_cadext ,
Thanks for your new idea,
I have seen the problem. It worked.
AutoCAD Inside the Factory
