ObjectARX
Help needed to find sample code for File -> Export Layout to Modelspace drawing
3 REPLIES 3
309 Views, 3 Replies
Hello All,
I am looking for sample code to provide this type of capability for AutoCAD Mechanical 2011.
Any help would be greatly appreciated,
Bob
3 REPLIES 3
owenwengerd
Your question is pretty nebulous. It might be helpful if you can provide some information about what exactly you've tried that didn't work, or what specific function you're interested in sample code for.
Owen Wengerd
ManuSoft
Sorry if this sounded ambiguous.
The use case for this is to open an Inventor dwg file, use the File SaveAs Export Layout to modelspace drawing option, close the drawing and repeat for the next Inventor dwg file.
I was looking for the needed method under the document object but there doesn't appear to be anything in the SaveAs or the Export methods to accomodate this.
Thanks for any light that you can shed.
Bob
owenwengerd
If you're after a managed code sample, I recommend to post in the .NET group. This group is for C++ ObjectARX API questions.
Owen Wengerd
ManuSoft
Technology Administrators
