ObjectARX
getGeomExtents creates wrong data
4 REPLIES 4
ynapeu
330 Views, 4 Replies
When I subtract a second cylinder from a cylinder, the GeomExtent increases. Can something like this happen?
The Original Zylinder has (-15,-15,0) (15,15,100)
the Zylinder with the differenz Solid is 0.00015 greater.
4 REPLIES 4
tbrammer
in reply to: ynapeu
Which AutoCAD version are you using? I tested with AutoCAD 2020 and 2024 like this:
  • _SUBTRACT thin cylinder from tall cylinder
  • _LIST for the resulting cylinder using LUPREC=8.
The result is shown in screenshot below. It equals the bounding box of the initial cylinder for both versions.
(German version. "Untere/Obere Begrenzung" = "Lower/Upper Boundary", "Begrenzungsrahmen"="Boundary box")
I didn't test getGeomExtents() explicitly.
Can you please check whether getGeomExtents() yields different results than _LIST shows?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
ynapeu
in reply to: tbrammer
Hello
The output from the list command is okay.
i use the following Code pEnt is the Solid
in Autocad 2022 the date will be okay, in Autocad 2024 i get some small differences.
AcDbExtents extents;
pEnt->getGeomExtents(extents);
AcGePoint3d amax;
amax = extents.maxPoint();
AcGePoint3d amin;
amin = extents.minPoint();
ads_printf(L"\nmax=%g,%g,%g  min=%g,%g,%g", amax.x, amax.y, amax.z, amin.x, amin.y, amin.z);
tbrammer
in reply to: ynapeu
On my system I get on both AutoCAD 2022 and 2024:
  Name Value Type
maxpt {x=15.000150220923764 y=15.000000000000000 z=100.00000000000000 } AcGePoint3d
AcGeContext::gTol.equalPoint() is 1e-10.
AcGeContext::gTol.equalVector() is 1e-12.
0.00015 is several orders of magnitude larger than this. The ARX docs makes no statement about the exactness of getGeomExtents().  It would be interesting how AutoCAD calculates the dimensions that _LIST prints. Obviously the deviation should be visible with LUPREC=8.
If you need higher accuracy you could try to use the BREP API to analyze the 3DSOLID.
ynapeu
You are right, both (Autocad 2022 and Autocad 2024) get the same result.
Thanks for yor help, the BREP creates correct results.
AcBrBrep myrep;
myrep.set(*(AcDb3dSolid*)pEnt);
AcGeBoundBlock3d block1;
myrep.getBoundBlock(block1);
block1.getMinMaxPoints(amin, amax);
ads_printf(L"\nbrepmax=%g,%g,%g min=%g,%g,%g", amax.x, amax.y, amax.z, amin.x, amin.y, amin.z);
this will print the correct Bounding box.
brepmax=15,65,100 min=-15,35,0
AutoCAD Inside the Factory
