ObjectARX
Find intersection of 3dface(acdbFace) with line (acdbline)
8 REPLIES 8
Message 1 of 9
majklha
768 Views, 8 Replies
A have group of 3dFaces defining some terrain surface and I need get the high in degined 2d origin. It means intersection this surface (part of surface) with vertical line gone througth this 2d point.
How to do it?
8 REPLIES 8
Message 2 of 9
Alexander.Rivilis
in reply to: majklha
AcDbFace::getPlane(...) -> AcGePlane
AcDbLine -> AcGeLineSeg3d
AcGePlane::intersectWith with AcGeLineSeg3d return your point.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
majklha
in reply to: Alexander.Rivilis
So, instead AcGeLineSeg3d I can use AcGeLine3d. Thanks.
Message 4 of 9
Alexander.Rivilis
Yes. You can use AcGeLine3d as infinitive line.
Expert Elite Member
Message 5 of 9
majklha
But I have once more question - how do I recognize, if the interception point lies on the 3dFace (between the bordered line) or outside? Because the AcGePlanar is infinity, is not it?
Message 6 of 9
ynapeu
maybe you use AcGeBoundedPlane
Message 7 of 9
majklha
in reply to: ynapeu
Great advice.
Message 8 of 9
majklha
in reply to: ynapeu
I have found problem with AcGeBoundedPlane. It is bordered only from two sides, third is infinity. What should I do with it?
Message 9 of 9
ynapeu
Maybe you create 2 BoundedPlane if the intersection Point lays on the 2 boundedplanes you get the intersection point.
|----------     Boundedplane 1     Boundedplane 2 |
AutoCAD Inside the Factory
