static void MyGroupMyCommand()
bool flag = true;
AcDbObjectId idBTR;
AcDbEntity* pEnt = NULL;
while (flag)
AcDbBlockTablePointer pBlkTbl(acdbCurDwg(), AcDb::kForWrite);
if (Acad::eOk != pBlkTbl.openStatus()){ flag = false; break; }
AcDbBlockTableIterator* pIt = NULL;
Acad::ErrorStatus es = pBlkTbl->newIterator(pIt);
if (Acad::eOk != es){ flag = false; break; }
std::unique_ptr<AcDbBlockTableIterator> apIt(pIt);
for (apIt->start(); !apIt->done(); apIt->step())
AcDbBlockTableRecord* pBTRecord = NULL;
if (apIt->getRecord(pBTRecord, AcDb::kForWrite) == Acad::eOk)
AcDbObjectPointer<AcDbBlockReference> pEnt(pBTRecord->objectId(), AcDb::kForWrite);
if (pEnt.openStatus() == Acad::eOk)
AcDbVoidPtrArray entitySet;
pEnt->explode(entitySet);
pBTRecord->close();
Solved by tbrammer. Go to Solution.
@2557003216 is right: You must either post the results in entitySet (casted to AcDbEntity*) to the database or delete them.
But what exactly do you want to achive? You are iterating over all Blocks in the drawing. Do you really want to explode all blockreferences (BREFs) in all blocks? And if so: Where would you post their fragments to? It makes no sense to post them to the modelspace.
I assume you want to explode all BREFs in the modelspace, post their contents to the modelspace and erase the original BREF. This is what the EXPLODE command would do if you select all BREFs in the modelspace.
You can get the ID of the modelspace like this:
#include <dbsymutl.h>
AcDbDatabase *pDB = acdbCurDwg();
AcDbObjectId IdModelSpace = acdbSymUtil()->blockModelSpaceId(pDB);
How do you want to deal with nested blocks? What if block A contains BREFs to block B which contains BREFs to C and so on?
It is important to distinguish exactly between a "block" (AcDbBlockTableRecord) and "block reference" (AcDbBlockReference, BREF). Let's say you have a block "X" and a BREF to it. If you make 99 copies from the BREF then there is only one block "X". If you explode or erase all 100 BREFs to "X" there is still this one block "X" - until you PURGE it.
You can't "explode" a block. You can explode a BREF, which will copy the block's entities to the BREF's owner block. Exploding a BREF will not modifiy the block it referenced!
A block can't have a "block inside". It can have BREFs inside. You can explode BREFs within a block with the BEDIT command.
If I understand you correctly, you want to explode BREFs (all? selected?) in the modelspace recursively so that there are no more BREFs in the modelspace. So starting with the attached Explode.dwg you would like to get the result on the far right side. Correct?
That's it, explode all the blocks in model space.
I don't know, why my writing wasn't successful
1x "housing" Do not explode
This can't work:
if (apIt->getRecord(pBTRecord, AcDb::kForWrite) == Acad::eOk) {
// pBTRecord ist a block (AcDbBlockTableRecord),
// NOT a BREF (AcDbBlockReference)
// ^- Here you tried to open a BREF with the Id of a block.
if (pEnt.openStatus() == Acad::eOk) // No way!
Try this:
#include <dbsymutl.h> // for acdbSymUtil()
AcDbObjectIdArray explodedBrefs;
AcDbVoidPtrArray brefFragments;
AcDbDatabase* pDB = acdbCurDwg();
Acad::ErrorStatus es;
// Get the modelspace
AcDbObjectPointer<AcDbBlockTableRecord> modelspace(IdModelSpace, AcDb::kForRead);
if (modelspace.openStatus() == Acad::eOk) {
// Now let's iterate over all entities in the modelspace
AcDbBlockTableRecordIterator* it=nullptr;
es = modelspace->newIterator(it);
if (it && (es==Acad::eOk)) {
AcDbObjectId entityId;
for (it->start(); !it->done(); it->step()) {
es = it->getEntityId(entityId);
AcDbObjectPointer<AcDbBlockReference> bref(entityId, AcDb::kForRead);
if (bref.openStatus() == Acad::eOk) {
// We found a BREF!
es = bref->explode(entitySet);
if (es == Acad::eOk) {
brefFragments.append(entitySet);
explodedBrefs.append(entityId);
// Don't append the fragments while iterating over the modelspace
delete it;
// Now append the new explosion fragment entities
es = modelspace->upgradeOpen(); // must be write enabled now.
for (void *p : brefFragments) {
AcDbEntity *ent = (AcDbEntity*)p;
es = modelspace->appendAcDbEntity(ent);
if (es==Acad::eOk)
ent->close();
else
delete ent; // avoid memory leak.
// Now erase the exploded BREFs
for (AcDbObjectId& brefId : explodedBrefs) {
AcDbObjectPointer<AcDbBlockReference> bref(brefId, AcDb::kForWrite);
bref->erase();
If you want to explode the BREFs recursively use this function instead of bref->explode(entitySet):
Acad::ErrorStatus ExplodeRecursive(AcDbBlockReference* bref, AcDbVoidPtrArray& entitySetTotal)
Acad::ErrorStatus es, esSub;
AcDbBlockReference* subBref = nullptr;
for (void* p : entitySet) {
if (subBref = AcDbBlockReference::cast((AcDbEntity*)p)) {
esSub = ExplodeRecursive(subBref, entitySetTotal);
if (esSub == Acad::eOk)
delete subBref;
else
entitySetTotal.append(subBref);
else
entitySetTotal.append(p);
return es;
Great way to explode BlockRefs inside Blockrefs, thanks for sharing this stuff.
What do you mean by "fry"? I assume that you mean "explode", right?
You can use both ExplodeRecursive(bref, entSet) or bref->explode(entSet) on any AcDbBlockReference *bref whether it resides in the modelspace or in any other "outer" block. There is no difference. In both cases you must erase the exploded BREF and append the resulting entSet to the AcDbBlockTableRecord that owns the BREF.
