Since you are building with the /clr switch you got warnings when you
compiled that __fastcall is incompatible with /clr. You need a little thunk
library that exports these fastcall functions as stdcall. I put together one
some time ago (attached)
Hopefully it will work for you,
Albert
"SDec" <Stephane.Decary@videotron.ca> wrote in message
news:40115dff$1_3@newsprd01...
> i use ObjectArx2004, with Acad2004
> with this libraries
> rxapi.lib acdb16.lib acge16.lib acgiapi.lib achapi16.lib acad.lib
> acedapi.lib adui16.lib acui16.lib
> "Byron Blattel" <byronatcadwerxdotnet> wrote in message
> news:40114f56$1_1@newsprd01...
> > What version of ObjectARX are you building?
> > If 2004 are you linking with acdb16.lib?
> > Best regards,
> > Byron Blattel
> > CADwerx--Applications for AutoCAD
> > Autodesk Registered Developer
> > Contact Info @
http://www.cadwerx.net> > Custom Programming Services - ObjectARX/C++/MFC/ASP/STL/ATL/ISAPI...
Attachment not added (too large): "fastthunk.lib"
