ObjectARX
Draw a block from external reference inside a custom entity's subWorldDraw function.
1 REPLY 1
rudolfkorcsmaros
351 Views, 1 Reply
Hi there!
I used c++ to create a custom entity. Now, I have a block inside an external dwg file. How can I draw that block inside the custom entity's subWorldDraw function, as part of the entity.
1 REPLY 1
tbrammer
in reply to: rudolfkorcsmaros
This is how you can draw the entities in the block with the block transformation of the BREF:
void DrawBref(AcGiWorldDraw *mode, AcDbBlockReference* bref)
	AcDbBlockTableRecord *block;
	Acad::ErrorStatus es;
	if ((es = acdbOpenObject(block, bref->blockTableRecord(), AcDb::kForRead)) == Acad::eOk)
		AcDbBlockTableRecordIterator* blkIter = 0;
		if (block->newIterator(blkIter) == Acad::eOk) {
			AcDbEntity* ent;
			mode->geometry().pushModelTransform(bref->blockTransform());
			for (; !blkIter->done(); blkIter->step()) {
				if (blkIter->getEntity(ent, AcDb::kForRead) == Acad::eOk) {
					mode->geometry().draw(ent);
					ent->close();
			mode->geometry().popModelTransform();
			delete blkIter;
		block->close();
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
AutoCAD Inside the Factory
