ObjectARX
Debugging Autocad 2016 in VS2012
3 REPLIES 3
nggarnaud
713 Views, 3 Replies
Dear all
I am stepping into debugging my api, and i have problems with some execptions. How can i fix it?
Thank you in advance
My project
  • C++
  • Build fine with solution platforms x64
  • Net Framework is set to 4.5 but that information doesn't appears in my project file.
  • I had installed windows kits 8.1 and 10 with gflags but don't know how to use it properly;
Symptoms
  • Using " Start debugging command "
  • Autocad 2016 takes more than 10 mins to start;
  • As a result of that i can't use my custom command
Debugging config :
  • Just my code;
  • Symbols are loaded from //symbols.autodesk.com/symbols
  • Others symbols are loaded from my pdb file
  • Edit and continue
3 REPLIES 3
tbrammer
in reply to: nggarnaud
Do you see these problems only when debugging?
So, when you start AutoCAD normally and ARXLOAD your app everything works?
In this case I would try a repair installation of VisualStudio. Are you using VS2012 with Update 4?
Or did you activate too many exceptions (Debug->Windows->Exceptions)? Reset them to default.
Otherwise: Could it be that your AutoCAD user profile es broken? Try to start acad.exe with the parameter /p myProfile. This will create a new profile named "myProfile".
Does debugging work when you compile one of the ARX samples?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
nggarnaud
in reply to: tbrammer
Vs2012 with upadate 4Vs2012 with upadate 4
Hello sir,
Scenario 1: When i load manually my api in autocad 2016, things works well. But the problem happens when i use my arx command. This force Autocad 2016 to start debugging.
Scenario 2: When i start debugginh in vs 2012, i builds fine. But Autocad takes longer to starts. That didn't allow me to use arx and appload commands ( last week).
I had reinstalled autocad 2016 last weekend, and now i am repairing vs2012.I will also follow your new suggestions and let you know how its goes.
Cheers
nggarnaud
Hello everyone
I followed your instruction. Things are working well when i build, load and run a traits.arx in AutoCAD 2016. But it doesn't work with my API.
  • Repaire VS2012
  • Reinstalled AutoCAD 2016 and created a proflie ;
  • Build, load nad run traits.arx = Success, but failed with my api;
 Should i use the same settings that was used for Samples\Graphics\Traits.sln?
My project was created using the instructions in Sparring with Autodesk® ObjectARX®—Round 2 Stepping into the Ring Lee Ambrosius\ Create a project from scratch, because unble to create a new project using Autodesk template.
Please Helppppp!!!!
AutoCAD Inside the Factory
