ObjectARX
Custom AcDbEntity Contain BlockReference subGetOsnapPoints Error
2 REPLIES 2
mengxiangge
481 Views, 2 Replies
Dear developer:
  I have create create a custom entity which contain a AcDbBlockReference.
when i located it at origin(0,0,0), its osnap is right ,contain kOsModeNear and kOsModePerp.
but when i move the entity ,its snap begin make some error which its  kOsModeNear and kOsModePerp osnap is not effect.
  please tell me the reason which make this problem and tell me the way how to get the right osnap.
  i have attach a git from which you can know the error clearly.
  the code block is blow
// .h
class AsdkBlockReference : public AcDbEntity
public:
	ACRX_DECLARE_MEMBERS(AsdkBlockReference);
	AsdkBlockReference();
	~AsdkBlockReference();
	std::shared_ptr<AcDbBlockReference> mBlock_reference;
	AcGePoint3d mOrigin;
	AcGeMatrix3d mMatrix3d;
protected:
	virtual Adesk::Boolean  subWorldDraw(AcGiWorldDraw*);
	Acad::ErrorStatus       subTransformBy(const AcGeMatrix3d&);
	virtual Acad::ErrorStatus subGetOsnapPoints(AcDb::OsnapMode     osnapMode,
		Adesk::GsMarker     gsSelectionMark,
		const AcGePoint3d& pickPoint,
		const AcGePoint3d& lastPoint,
		const AcGeMatrix3d& viewXform,
		AcGePoint3dArray& snapPoints,
		AcDbIntArray& geomIds) const;
void addAsdkBlockReferenceObject();
// .cpp
#include "pch.h"
#include "AsdkBlockReference.h"
ACRX_DXF_DEFINE_MEMBERS_WITH_PROPERTIES(
    AsdkBlockReference, AcDbEntity,
    AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent,
    AcDbProxyEntity::kNoOperation,金地墙2,
    GemWallStyle Sample
    | Product Desc : A description for your object
    | Company : Your company name
    | WEB Address : Your company WEB site address,
    AsdkBlockReference::makeMembers
AcDbHandle AsdkBlockReference::mHandle = nullptr;
AsdkBlockReference::AsdkBlockReference()
AsdkBlockReference::~AsdkBlockReference()
Acad::ErrorStatus
AsdkBlockReference::subTransformBy(const AcGeMatrix3d& xfm)
    assertReadEnabled();
    mMatrix3d = xfm;
    if(mBlock_reference)
        mBlock_reference->transformBy(xfm);
    return Acad::eOk;
Adesk::Boolean AsdkBlockReference::subWorldDraw(AcGiWorldDraw* pW)
    pW->geometry().draw(mBlock_reference->drawable());
    return Adesk::kTrue;
Acad::ErrorStatus AsdkBlockReference::subGetOsnapPoints(AcDb::OsnapMode     osnapMode,
    auto ima = mMatrix3d.inverse();;
    auto pickBasePoint = const_cast<AcGePoint3d&>(pickPoint).transformBy(ima);
    auto lastBasePoint = const_cast<AcGePoint3d&>(lastPoint).transformBy(ima);
    return mBlock_reference->getOsnapPoints(osnapMode, gsSelectionMark, pickBasePoint, lastBasePoint, viewXform, snapPoints, geomIds);
    ads_name      ename, sset;
    if (RTNORM == acedSSGet(NULL, NULL, NULL, NULL, sset))
        struct resbuf* rb;
        if (acedSSNameX(&rb, sset, 0) != RTNORM)
            acedSSFree(sset);
            return;
        if (rb == NULL || rb->restype != RTLB)
            assert(0);
            return ;
        rb = rb->rbnext; // Bump up to the selection method, always after RTLB.
        rb = rb->rbnext; // Bump up to the first name, always after sel method.
        ename[0] = rb->resval.rlname[0];
        ename[1] = rb->resval.rlname[1];
        AcDbEntity* ent = NULL;
        AcDbObjectId polyId;
        acdbGetObjectId(polyId, ename);
        auto t = acdbOpenAcDbEntity(ent, polyId, AcDb::kForRead);
    	auto tBlock = static_cast<AcDbBlockReference*>(ent);
        auto tBlockRecordId = tBlock->blockTableRecord();
        ent->close();
        AsdkBlockReference* pNewObj = new AsdkBlockReference;
        pNewObj->mOrigin = AcGePoint3d(0, 0, 0);
        auto pShareBlock = std::make_shared<AcDbBlockReference>(
            pNewObj->mOrigin, tBlockRecordId);
        pNewObj->mBlock_reference = pShareBlock;
        AcDbBlockTable* pBlockTable;
        acdbHostApplicationServices()->workingDatabase()
            ->getSymbolTable(pBlockTable, AcDb::kForRead);
        AcDbBlockTableRecord* pBlock;
        pBlockTable->getAt(ACDB_MODEL_SPACE, pBlock,
            AcDb::kForWrite);
        AcDbObjectId objId;
        auto es=pBlock->appendAcDbEntity(objId, pNewObj);
        pNewObj->recordGraphicsModified();
        pBlock->close();
        pBlockTable->close();
        pNewObj->close();
Labels (1)
2 REPLIES 2
daniel_cadext
in reply to: mengxiangge
I was able to get a sample to work,
there's another subGetOsnapPoints to override. it's weird that  just returning
ref.getOsnapPoints(osnapMode, gsSelectionMark, _pickPoint, _lastPoint, viewXform, snapPoints, geomIds, xform); doesn't work.
Anyway if this seems to work, hope it helps. maybe someone with more knowledge can help
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
mengxiangge
in reply to: daniel_cadext
Dear daniel,
thanks your help! it's works .
i only call this method: ref.getOsnapPoints(osnapMode, gsSelectionMark, _pickPoint, _lastPoint, viewXform, snapPoints, geomIds, xform);
Technology Administrators
