first question,I use below code to close all document,but every one is not same,get pDocIter count,often is not equal to current Reality, why?
void CloseAll()
AcApDocumentIterator* pDocIter=acDocManager->newAcApDocumentIterator();
AcApDocument* pDoc;
while(!pDocIter->done())
pDoc=pDocIter->document();
acdbSetDbmod(pDoc->database(),0);
acDocManager->closeDocument(pDoc);
pDocIter->step();
delete pDocIter;
pDocIter=NULL;
the second question,a document with name "drawing1",and it is no save to disk,then save this document to "c:\test.dwg",how can i know "c:\test.dwg" is from "drawing1"? i use Reactor ,but in VC++ and lisp , the result is not same to VBA,I think the vba is right
Sorry,My English is so bad,
;;lisp code: myfun1 is same myfun2 with result
(defun myfun1(a b)
(princ b)
(vlr-dwg-reactor nil (list (cons :vlr-beginSave 'myfun1)
(cons :vlr-saveComplete 'myfun
'below is vba,For the first time ,msgbox "drawing1",Second times is "c:\test.dwg"
'I think the vba is right
Private Sub AcadDocument_BeginSave(ByVal FileName As String)
MsgBox FileName
End Sub
Private Sub AcadDocument_EndSave(ByVal
//below is VC++ code ,is same to lisp
void CaiqsComCtl::beginSave(AcDbDatabase* pDB, const char* pIntendedName)
AfxMessageBox(pIntendedName);
void CaiqsComCtl::saveComplete(AcDbDatabase* pDb, const char* pActualName)
AfxMessageBox(pActualName);
