I want to start debuging my arx application, but can't find information about it or information I found don't work for me.
I have:
AutoCAD Civil 3D 2022
Visual Studio Community 2019 v16.11.11
Have installed ObjectARXWizard2022.msi and can find it in VS but it stops at Create button.
Setting project name and pressing "Create" button button become disabled for few minutes and after few minutes can press again, but project is not created. So, can't use Wizard for setting default settings.
I had found this https://forums.autodesk.com/t5/objectarx/debgging-objectarx-application/td-p/6655281
and used information in it.
Loaded ARX compiled in debug mode to AutoCAD.
In Attach to Process window set "Native code" and selected acad.exe
All my breakpoints got yellow triangles saying "The breakpoint will not currently be hit. No symbols have been loaded for this document."
Can't find my arx in Modules window. I think it should be here? My commands in AutoCAD works.
I tried to copy Autodesk.arx-2022.props from Wizard install directory, but it did not helped.
Is here somewhere detailed instruction for arx project setup for debuging?
