acedssget for COM accessed objects
karl.sch1983
karl.sch1983
I had a previous post here to access Civil 3d objects. Thanks to @Alexander.Rivilis  and @zrobert I successfully created the application and was able to manipulate those by accessing properties of relevant objects through com. Taking it to the next step, I got a request to pick an object in the editor and then manipulate its properties. I just cant seem to successfully get the relationship between the picked entity and casting/converting it to the necessary object to manipulate it. I looked at this post and tried to implement something similar.
AcDbObjectId id; acdbGetObjectId(id, en);
AcDbObjectPointer<IAeccSurfacePtr> pEnt(id, AcDb::kForWrite);	// is this correct for accessing a surface?
if (pEnt.openStatus() == Acad::eOk)
	//manipulate pEnt properties
of course it fails.
Can someone please provide any helpful info on how to cast to the right entity. Any helpful links? I have googled over several days and cannot find anything. I just need to be able to manipulate the picked civil 3d entity which is a surface. Thanks for all your help in advance.
p.s. I also posted this in the Civil3D customization forums here
zrobert
Hello Karl;
I haven't specifically used object selection in a COM environment, but I think this might help you.
This is a link to Kean's blog where he explains the "conversion" of the classic ObjectId to a COM object.
This is a .NET environment, however, the essential line of code is
// Let's use the COM API to get a COM reference
// to the hatch (as a base object)
object obj2 = oAcad.ActiveDocument.ObjectIdToObject(
obj.ObjectId.OldId
The IAcadDocument* object in the c++ environment also has this method (ObjectIdToObject).
So, when you get the ObjectID, try to convert it to a COM object this way.
I hope it helps you.
karl.sch1983
Thanks @zrobert, I will explore the ObjectIdToObject method and report back.
