acdbregion getArea =0,but the area of region is not 0 in fact
475867377
Message 1 of 8
475867377
the region is unioned by two regions .but the area get by api getArea() is 0.in cad property window can not show area and perimeter. i use command "area" to caculate area but failed. is there anything wrong?
Replies (7)
Message 2 of 8
tbrammer
Can you please post the DWG with the region in question?
You wrote that the region is a union of two regions. Do both have a valid area? Can you post a DWG with those regions as well?
Do you know how the regions were created?
Which AutoCAD version are you using?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 8
475867377
the region is created by api booleanOper(AcDb::kBoolUnite).it have merged the other region.the version of CAD is 2018.
Message 4 of 8
tbrammer
Again: Can you please post the DWG with the region in question and if possible a DWG with the two regions that you merged?
Have you tried to open the DWG with _RECOVER?
Can you check the DWG with a newer version of AutoCAD?
Message 5 of 8
475867377
this is the dwg.
Message 6 of 8
tbrammer
I can reproduce the behaviour with AutoCAD 2024.
The two regions in the DWG are valid. But if I _UNITE them, the resulting region looks OK, but it doesn't show geometry properties like area and circumference.
If I use the command SNOOPENTS from ArxDbg.arx (<ARX>\samples\database\ARXDBG) I get the error messages
ERROR calling AcDbRegion::getAreaProp()
ARX ERROR: eInvalidInput
Also the AutoCAD command _AREA _OBJECT can't calculate the area.
The AutoCAD command _MASSPROP however displays values for area (Fläche) and circumference (Umfang):
The geometry of one region is very complex. It has a lot of "touching points" that makes it hard to decide whether there is one region with a hole or multiple separate regions. I suppose that this causes the problem.
Looks like a bug. So I think this is a case for the AutoCAD product support.
I managed to create a valid united region like this:
  1. _EXPLODE all regions to lines
  2. Create new regions with _REGION and select all lines.
  3. Unite all new regions with _UNITE
See attached DWG. I think you can do the same programmatically with ObjectARX. This could be a workaround for you.
Message 7 of 8
475867377
i have resolved the problem.the region is create  by the AcDb3dPolyline which vertexs ' z value is 0.i change to AcDbPolyline and setElevation(0),then the problem is resolved.thank you for your help.
Message 8 of 8
475867377
