worldDraw() question
alex_b
alex_b
Hi
I have a few questions regarding worldDraw():
1. please consider:
class A : public AcDbEntity { };//custom class
class B : public AcDbEntity { };//custom class
class C : public AcDbEntity {
A a;
B b;
public: double f;
Does acad call a.worldDraw() or does C::worldDraw() have to (optionally) do it? The same question for dwgIn/OutFields().
Does b.worldDraw() have access to f?
2. To display a hatch inside a.worldDraw(), is there a hatch() function callable from there, or do I have to embed an AcDbHatch object inside my custom object?
alex
AutoCAD knows nothing about private members of
your custom object's class, so the worldDraw() of
those instances will not be called. You would have
to do it explicitly the worldDraw() of the containing
database-resident entity.
AFAIK, there's no hatch() function that draws hatching
geometry, so you would either have to calculate the
hatch geometry yourself, or create and use a hatch
entity in your worldDraw().
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:[email protected]...
Hi
1. please consider:
A a;
B b;
public: double f;
custom object?
alex
alex_b
Thanks, Tony.
The same answer?
Its not really OARX, but I can't figure it out.
>AFAIK...
I meant solid hatch. I can't calculate it, and embedding a hatch object just to access its worldDraw() seems inefficient to me.
alex
Yes, same answer.
AutoCAD does not know anything about custom objects
that are not database-resident, so don't expect it to call
any of there members.
No.
Thanks, Tony.
The same answer?
>AFAIK...
alex
alex_b
OK.
One more question: can a custom object 'know' the reason its worldDraw() method was called?
I mean w/o resorting to checking the current command.
alex
Look at the context() member of the parameter to worldDraw(),
and the AcGiContext type it returns.
OK.
method was called?
alex
alex_b
Tony:
Context(() worked for me.
alex
