What is the relation between explode and erase ?
Hi all ,
I just want to know what is the relation between explode command and erase event ?
If there is a relation then how does the erase event is invoked after explode ?How can I achieve that ?
Please help.
Pradeep Sharma
thierry_prince
So far I know, when you use the EXPLODE command in AutoCAD :
 1- the AcDbEntity::explode() derived method is called of each entity you selected, so AutoCAD can get the new entities to create,
 2- the new entities are added to the database(),
 3- the subErase(true) method of each object is called to erase the exploded objects.
Perhaps the points 2- and 3- should be exchanged.
I hope this helps you.
Thierry
