VisualStudio.NET 2002
If I compile with VS.NET 2002 then I get the fatal Error:
File 'mfc42.lib' not found
If I copy the old Files from VC6, the app is not running in Acad2004
What can I do ??
Anything compiled with VC2002 for Autocad 2004, should NOT be using the
mfc42 libraries. They have to use the mfc70 libraries, otherwise there will
be memory conflicts and fatals.
Yes I now it, but if I build a new one with the AppWizard then I get the
Error!
Regard it is the Wizard for NET2002!
"Randy Sanders" schrieb im Newsbeitrag
news:4305C2D44926C6A213498DBD7F609A0D@in.WebX.maYIadrTaRb...
will
Hi, Georg Erlenhoff!
Look for Options->VC++ Directories in Visual Studio NET. It must do not
point to VC++ 6 directory.
Also any addition lib files can not refer to mfc42.lib
Best Regards,
Alexander Rivilis
The Directories dosn't have a Point to VC++6!
The Compilererror is: File 'mfc42.lib' not found
Wy the Compile ask for that File? wy they don't use mfc70.lib?
I didn't tell them to use mfc42.lib.
The project is build with the ARX-Wizard for NET2002.
It is an empty Project, only for testing
Thank's for Help
Georg
"Alexander Rivilis" schrieb im Newsbeitrag
news:75DBF550B14DF49670F904F6EAFC3454@in.WebX.maYIadrTaRb...
> Best Regards,
> Alexander Rivilis
Make sure that your path to the Autocad libraries are not pointing to the
2002 libraries.
"Georg Erlenhoff" wrote in message
news:F38AAA7069B5AB3A27D37CC0197009FA@in.WebX.maYIadrTaRb...
> Thank's for Help
> Georg
> > Best Regards,
> > Alexander Rivilis
GE> The Directories dosn't have a Point to VC++6!
May be VC++ Directories point to ObjectARX 2000 (or ObjectARX 2002)?
Best Regards,
Alexander Rivilis
