Using acedSSGet with :V selection mode
Message 1 of 8
I need to assign some XData values to a solid (box) face.
I try to use:
ads_name selSet;
acedSSGet( L"_:V", nullptr, nullptr, nullptr, selSet );
to let user specify the face. It seems to work fine, but how can I then get the face(s) selected ?
I tried:
ads_name entity;
acedSSName( selSet, 0, entity );
but it returns the entire solid...
Replies (7)
Message 2 of 8
Alexander.Rivilis
You have to use not  acedSSName but acedSSNameX. As an example you can see in the ObjectARX SDK: samples\entity\polysamp
hilit.cpp has the function hilitSolid which allow to highlight selected Face/Edge of AcDb3dSolid.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
Alexander.Rivilis
@Anonymous wrote:
...I need to assign some XData values to a solid (box) face....
It is impossible to assign Xdata to AcDb3dSolid  face, because XData can be assigned only to the whole object/entity
Face of AcDb3dSolid is not independent entity.
Expert Elite Member
Message 4 of 8
I've tried this solution. The problem is that I want to use:
acedSSGet( L"_:V", NULL, NULL, NULL, sset )
and not the:
acedSSGet(NULL, NULL, NULL, NULL, sset)
Because in the first case user can see what he selects. The faces get highlighted when mouse hovers over them. In the latter case the entire solid is being selected.
And when I use the selection mode string the
pEnt->getSubentPathsAtGsMarker( AcDb::kFaceSubentType, marker, pickpnt, xform, numIds, subentIds );
returns different face, then the one I've selected.
By the way, it is very strange, that there is a new special selection mode and no sample code uses it...
Message 5 of 8
I expected this. AFAIK the face is not a DBRO. But I suppose I could assign to the solid the xdata containing face number along with the data which belongs to the face. I suppose there is some kind of consistent face numbering, to know for example which is the first face of the solid box, the second, etc.
Message 6 of 8
Alexander.Rivilis
Maybe this code will be a sample:
static void RivilisTestGetSubent() {
  ads_name ss;
  AcArray<SubentType> subTypes;   subTypes.append(kFaceSubentType);
  acedSSSetSubentTypes(subTypes);
  if (acedSSGet(_T("_:V"), nullptr, nullptr, nullptr, ss) == RTNORM)
    Adesk::Int32 nEnts = 0, nSubs = 0;
    acedSSLength(ss, &nEnts);
    for (int i = 0; i < nEnts; i++)
      acedSSSubentLength(ss, i, &nSubs);
      for (int j = 0; j < nSubs; j++)
        AcDbFullSubentPath path;
        acedSSSubentName(ss, i, j, path);
        AcDbObjectId id = path.objectIds()[0];
        AcDbObjectPointer<AcDb3dSolid> pSolid(id, AcDb::kForWrite);
        if (pSolid.openStatus() == Acad::eOk) {
          AcCmColor cm; cm.setColorIndex(1);
          pSolid->setSubentColor(path.subentId(), cm);
        } else {
          acutPrintf(_T("\nSelected entity is not solid!"));
          break;
    acedSSFree(ss);
Expert Elite Member
Message 7 of 8
This is really a sample! Thanks a lot, Alex.
It would take me a long time to invent this solution.
One more question, if you be so kind:
As I mentioned earlier I need to know which face is it (geometrically). For this I would need the coords of the face vertices. For now, I found the not very elegant solution for this task. Namely:
AcDbEntity* pEnt = nullptr;
pSolid->copyFace( path.subentId( ), pEnt );
AcDbRegion* pFace = AcDbRegion::cast( pEnt );
AcGePlane regionPlane;
pFace->getPlane( regionPlane );
and having the plane I could identify, which face it was and get the coords of vertices from the solid. Any better idea, please ?
Message 8 of 8
Alexander.Rivilis
This way is look like easiest. Other way is use BREP API.
Expert Elite Member
