use of AcEdJig with blocks
Hi all!
I want to implement a similar functionality to the Insert>Block function
in ACAD and therefor I want to use the AcEdJig class to get a
preview of the block going to be inserted. The user only has to select
a insertion position. I used the "elipsjig" Sample from the sdk and
modified the code for my special preferences.
The Problem is, that no preivew is drawn.
There is a small code snip:
void MyJig::doIt()
mPromptCounter = 0;
setDispPrompt("\nInsertion Point?: ");
AcEdJig::DragStatus stat = drag();
append();
AcEdJig::DragStatus MyJig::sampler()
DragStatus stat;
setUserInputControls((UserInputControls)
(AcEdJig::kAccept3dCoordinates
| AcEdJig::kNoNegativeResponseAccepted
| AcEdJig::kNoZeroResponseAccepted));
if (mPromptCounter == 0) {
static AcGePoint3d axisPointTemp;
stat = acquirePoint(m_CenterPt);
return stat;
In the following function the Ellipse was set in the example.
What should I do with my block right in here?
Adesk::Boolean MyJig::update()
switch (mPromptCounter) {
case 0:
break;
return Adesk::kTrue;
Any help would be appreciated.
Thanks, Markus
What are you returning in your AcEdJig::entity() override...
| Byron Blattel
| CADwerx---Applications for AutoCAD
| Autodesk Registered Developer
| email: byron@cadwerx.net
| web site: http://www.cadwerx.net
Hi!
Thanks for your help, but I fixed the problem I posted before by myself.
But now I have another problem with my AcEdJig class...
I already get the preview I want and the Block is inserted on the
position, which the user selects. But when I move the mouse over
the Block in ACAD I receive the following error:
** Undefined block #5
What does it mean?
The block is inserted with the AcEdJig::append() function.
I hope someone can help, Markus
Add to update method
mpBlkRef->setPosition(m_CenterPt);
this is my source code
mpBlkRef->setRotation(mAngle);
