Text Position change
I want to change the text position in the drawing that the other application made.
However, it doen't work pText->setPosition(). (setRotation is working).
In the properties, the geometry (position X/Y/Z) is grayed out and "apply" button is grayed out also.
What I have to change to do in first?
in the command windows, (entget (car (entsel))) is as follows.
Command: (entget (car (entsel)))
Select object: ((-1 . <Entity name: 7ffffb0c6e0>) (0 . "TEXT") (330 . <Entity name: 7ffffb069f0>) (5 . "37E6") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "AS_LAB") (62 . 4) (100 . "AcDbText") (10 811.124 648.269 0.0) (40 . 2.5) (1 . "50-SW-45532-S3A-5L") (50 . 5.45614) (41 . 1.0) (51 . 0.0) (7 . "romans") (71 . 0) (72 . 4) (11 827.56 632.25 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0))
CH Lee
artc2
If your text is anything other than baseline left justified, then you need to set the alignment point rather than the position point. The text data you show is for text that has baseline middle justification, so it needs to have its alignment point set instead of position point.
Thank you for your kind reply.
It works fine.
CH Lee
