Hi Alessandro,
Unfortunately there is no direct method do repeat ATTSYNC command. To achieve the same result, you can try the following steps: (1) open the block definition and block reference, (2) iterate though attribute references on block reference and find the appropriate attribute definition (using TAG as a search criteria), (3) use the setAttributeFromBlock to copy the new attribute.
Another option is to send ATTSYNC command:
[CommandMethod("AttsyncCmd")]
static public void AttsyncCmd()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
string bName = "blk1";
string command = "_ATTSYNC Name " + bName + "\n";
doc.SendStringToExecute(command, true, false, false);
If you are doing that inside a save & close operation, then yes it will not work. You need to P/Invoke a synchronous method such as "acedCommand". Here is an example:
[DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedCommand")]
private static extern int acedCommand(int type, __arglist);
[CommandMethod("acedCommand3")]
public void acedCommand3()
double rad = 2.5;
double[] center = new double[3] { 0, 0, 0 };
acedCommand(5005, __arglist("_.CIRCLE", 5009, center, 5001, rad, 5000));
Note for next time: you may want to post C#/VB.Net questions to the .Net section rather than ObjectARX (reserved for C++).
Philippe.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
Philippe Leefsma
Autodesk Developer Network
