Stretching Dimensions
EMD1954
EMD1954
I create a Dimension Style and it works fine, but when I stretch it, the text does not re-center.  Here's part of my code:
pDimTable->upgradeOpen();
pDimTblRecord = new AcDbDimStyleTableRecord;
pDimTblRecord->setDimscale(96.0);               // dim scale
pDimTblRecord->setDimtxt(0.25);                 // height of text
pDimTblRecord->setDimzin(0);                    // 0'-0"
pDimTblRecord->setDimblk(_T("_CLOSEDFILLED"));  // arrow type
pDimTblRecord->setDimunit(4);                   // architectural
pDimTblRecord->setName(csStyleName);
pDimTblRecord->setDimrnd(0.0);                  // round-off values set to none
pDimTblRecord->setDimtad(1); // sets vertical text position to above the line
pDimTblRecord->setDimtoh(0); // aligns text with the dimension line
pDimTblRecord->setDimjust(0);                   // Positions the text above the dimension line and center-justifies it between the extension lines
pDimTblRecord->setDimtxsty(recId);              // text style record id for "SIMPLEX" - see above
pDimTblRecord->setDimfrac(2);                   // fractions not stacked
What am I missing?
Ed
Kyudos
setTextPosition ?
EDIT:....sorry you're talking about dim styles not dims....I'd guess it's almost certainly to do with the text style associated with the dim style....is that centered? AutoCAD itself indicates this could be the DIMTAD, DIMJUST and DIMTXTDIRECTION variables
EMD1954
Yes sorry, it was for dimstyle.  FYI, if I add:
acedCommandS(RTSTR, _T("_DIMTEDIT"), RTSTR, _T("L"), RTSTR, _T("C"), RTSTR, _T(""), RTNONE);
after creating the dimension, it works fine.  Seems there some switch I'm not setting and I tried DDIMTIH, DIMTOFL, DIMSOXD and DIMATFIT.
