Space line, how to find the red boundary?
1127204185
Message 1 of 23
1127204185
Replies (22)
Message 2 of 23
tbrammer
ObjectARX has classes like AcDbSubDMesh that can represent meshes. But I don't think that there
is an API that can find the border lines.
Basically the algorithm would be like this:
1.) Build an index of all start- and endpoints of the lines.
2.) Now you can represent lines by index pairs. I.e. the four lines around face A are (0,1), (1,4), (0,3) and (3,4).
3.) Create a "connection map". I.e.:
std::map<unsigned, std::vector<unsigned> > connections;
connections[0].push_back(1);
connections[1].push_back(0);
connections[0].push_back(3);
connections[3].push_back(0);
connections[3].push_back(4);
connections[4].push_back(3);
connections[3].push_back(6);
connections[6].push_back(3);
4.) For every connection look for closed triangle- or quad-loops. I.e. (3,4) has two loops: face A and C. If a connection is within two loops, it is an inner connection. If it has only one loop, like (6,7) and (7,8) it is an outer boundary.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 23
tbrammer
You might find my code sample here useful.
But note that it works for triangles only. You must enhance the code so that it also works with quads.
Message 4 of 23
1127204185
The difficulty is how to find these closed areas?
A:0-1-4-3
B:1-2-5-4
D:3-4-7-6
C:4-5-8-7
Message 5 of 23
tbrammer
It's not too difficult.
Let's say you start at (3,4)
In the connections map you find the points connected to 3 and 4.
  • Set3: 0,6,9     (point 9 is left of point 3. It isn't drawn in my picture)
  • Set4: 1,5,7
We first check, whether there is a triangle:  Does one or two of the points in Set3 connect to 4?
If there are less than two triangle connections then we search for quad connections between Set3 and Set4.
In this case there is no triangle connection. But we easily find the two quad connections (0,1) and (6,7).
And now, because we found two connections, you can tell that (3,4) is an inner connection.
Message 6 of 23
1127204185
My algorithm,3-4 there are two results, proving that it is not a boundarytest.jpg
No. 1
3-4
No. 2
3-4-1
3-4-5
3-4-7
No. 3
3-4-1-0
3-4-1-14
3-4-1-2
3-4-5-2
3-4-5-10
3-4-5-8
3-4-7-6
3-4-7-8
No. 4
3-4-1-0-15
3-4-1-0-17
3-4-1-0-3  Found a closed body A
3-4-1-14-15
3-4-1-14-?
3-4-1-14-13
3-4-1-2-13
3-4-1-2-11
3-4-1-2-5
3-4-5-2-1
3-4-5-2-13
3-4-5-2-11
3-4-5-2-5
3-4-5-10-11
3-4-5-10-?
3-4-5-10-9
3-4-5-8-9
3-4-5-8-7
3-4-7-6-3 Found a closed body C
3-4-7-6-19
3-4-7-8-5
3-4-7-8-9
Message 7 of 23
1127204185
No. 1
6-7
No. 2
6-7-4
6-7-8
No. 3
6-7-4-3
6-7-4-1
6-7-4-5
6-7-8-5
6-7-8-9
No. 4
6-7-4-3-6  Found a closed body C
6-7-4-3-0
6-7-4-3-18
6-7-4-1-0
6-7-4-1-14
6-7-4-1-2
6-7-4-5-2
6-7-4-5-10
6-7-4-5-8
6-7-8-5-2
6-7-8-5-10
6-7-8-5-4
6-7-8-5-9
6-7-8-9-10
6-7-8-9-?
Message 8 of 23
tbrammer
Yep, you got the algorithm. Now you just need to code it 😁.
Message 9 of 23
1127204185
Still don't understand
 no.5
3-4-5-2-1-0
 no.6
3-4-5-2-1-0-3
Message 10 of 23
tbrammer
My idea was to search for triangles and quads only because your drawing only contains triangles and quads and because it is common to form shells from triangles an quads.
I would not search for loops that contain more than four points!
So neither 3-4-5-2-1-0  nor 3-4-5-2-1-0-3 is a "valid" loop.  I would check 3-4-5-2 and discard it, because 2 isn't connected to 3.
If you expect faces with more than 4 edges the algorithm becomes much more complex. In this case you have to "walk along" all possible paths and remember which points you have already visited. You will find a bunch of long loops that can be split into shorter loops like (3,4,5,2,1,0) => (3,4,1,0)+(4,5,2,1). These long loops must be sorted out.
Message 11 of 23
1127204185
I would search for loops that contain more than four points!
Message 12 of 23
tbrammer
Hm. Really? It's quite challenging to find an effective algorithm for this.
I already wrote one basic idea above: Walk along all possible paths and remember which points you have already visited. If you come to a point that you visited before you found a loop. Store all loops. You will find a bunch of long loops that can be split into shorter loops like (3,4,5,2,1,0) => (3,4,1,0)+(4,5,2,1). These long loops must be sorted out. Analyse the remaining short loops and look for single connections. These are the border lines.
If you find loops with 4 and more points the points may not be in the same plane and/or the face might be concave.
What is this?
  • If all four points 0,1,2 and 3 are within the same plane you have a triangle (0,1,2) and a concave quad (0,1,3,2).
    In this case (1,2,3) is the outer border.
  • Otherwise you have two triangles (0,1,2) and (1,2,3).
    In this case (1,3,2,0) is the outer border.
Now imagine loops with 5, 6, ... points.
Maybe it makes sense to look for points within (nearly?) the same plane while searching for loops.
Message 13 of 23
1127204185
Each edge can get 2 closed
6-7 -4-3-6
6-7-8-9-?-?...-?-19-6
Message 14 of 23
tbrammer
(6-7-8-9-?-?...-?-19) can be split into smaller loops. (6,7,4,3) can't. You must sort out all loops that can be split! I.e. consider (6,7,8,9,10,5,4,3,18,19). It includes the connected points (6,3), (7,4) and (5,8). So it can be split at these three connections in three steps:
  1. split at (6,3): (6,7,8,9,10,5,4,3,18,19) => (6,3,18,19) + (6,7,8,9,10,5,4,3)
  2. split at (7,4): (6,7,8,9,10,5,4,3) => (6,7,4,3) + (7,8,9,10,5,4)
  3. split at (5,8): (7,8,9,10,5,4)=(5,4,7,8,9,10) => (5,8,9,10) + (5,4,7,8)
Result: (6,3,18,19) + (6,7,4,3) + (5,8,9,10).
This includes (6,7) only once.
Message 15 of 23
1127204185
Problem code
static void MyGroupMyCommand1 () {
	ads_name sset;
	resbuf *rbList = acutBuildList(RTDXF0, _T("LINE"), RTNONE);
	int result = acedSSGet(NULL, NULL, NULL, rbList, sset);
	if (result != RTNORM) { return; }
	Adesk::Int32 length = 0;
	acedSSLength(sset, &length);
	Acad::ErrorStatus es = Acad::eOk;
	resbuf StartTime;
	acedGetVar(_RXST("TDUSRTIMER"), &StartTime);
	vector<AcGePoint3dArray> dat,dat2;
	vector<AcGePoint3dArray> dattemp1;
	AcGePoint3dArray dattemp,dat3;
	for (int i = 0; i < length; i++)
		ads_name ename;
		acedSSName(sset, i, ename);
		dattemp.removeAll();
		AcDbObjectId objId = AcDbObjectId::kNull;
		es = acdbGetObjectId(objId, ename);
		if (es != Acad::eOk) { continue; }
		AcDbEntity* pEnt = NULL;
		es = acdbOpenObject(pEnt, objId, AcDb::kForRead);
		if (pEnt->isKindOf(AcDbCurve::desc()))
			AcDbCurve* pCurve = AcDbCurve::cast(pEnt);
			AcGePoint3d staPt,entPt;
			pCurve->getStartPoint(staPt);
			pCurve->getEndPoint(entPt);
			AcGePoint3dArray pa1;
			pa1.append(staPt);
			pa1.append(entPt);
			dat2.push_back(pa1);
			dat3.append(staPt);
			dat3.append(entPt);
			pa1.removeAll();
			pCurve->close();
		pEnt->close();
	acedSSFree(sset);
	AcGePoint3dArray dat4 =deletePoint(dat3,1e-7);
	acutPrintf(_RXST("\ndat3: %d \n"), dat3.length());
    acutPrintf(_RXST("\ndat4: %d \n"), dat4.length());
	acutPrintf(_RXST("\ndat2: %d \n"), dat2.size());
	map<int, AcGePoint3d> dats;
	dats.clear();
	for (int i = 1; i < dat4.length()+1; i++)
		dats.insert(pair<int, AcGePoint3d>(i, dat4.at(i - 1)));
	vector<vector<int>> dat5;
	AcGePoint3d  pp0,pp1;
	for (int i = 0; i < dat2.size(); i++)
		pp0=dat2.at(i).at(0);
		pp1=dat2.at(i).at(1);
		int k1,k2;
		for(map<int, AcGePoint3d>::const_iterator it = dats.begin(); it != dats.end(); ++it)
			if (pp0.distanceTo(it->second) < 1e-7)
				k1=it->first;
			if (pp1.distanceTo(it->second) < 1e-7)
				k2=it->first;
	    vector<int> temp;
		temp.push_back(k1);
		temp.push_back(k2);
		dat5.push_back(temp);
		acutPrintf(_RXST("\n  %d = %d _ %d"), i,k1,k2);
		map<int, vector<int>> dat6;
		for (int i = 1; i < dats.size(); i++)
			vector<int> temp;
			temp.clear();
			for (int ii = 0; ii < dat5.size(); ii++)
				if (dat5.at(ii).at(0) == i)
					temp.push_back(dat5.at(ii).at(1));
				if (dat5.at(ii).at(1) == i)
					temp.push_back(dat5.at(ii).at(0));
			dat6.insert(pair<int,  vector<int>>(i, temp));
		vector<int> temp,temp1,temp2,temp3;
		vector<vector<int>> temps,temps1,temps2,temps3;
		for (int i = 0; i < dat5.size(); i++)
			int a1=dat5.at(i).at(0);
			int a2=dat5.at(i).at(1);
			temp.push_back(a1);
			temp.push_back(a2);
			temps.push_back(temp);
			while (temps1.size() != 2)
				temp3.clear();
				for (int ii = 0; ii < temps.size(); ii++)
					temp1=temps.at(ii);
					int a3=temp1.back();
					int a4=temp1.at(temp1.size() - 2);
					auto it1 =dat6.find(a3);
					vector<int> kk=it1->second;
					for (int iii = 0; iii < kk.size(); iii++)
                      temp3=temp1;
					  int a5 = kk.at(iii);
					  if ( a5 != a4  )
						temp3.push_back(kk.at(iii));
						temps2.push_back(temp3);
					  if ( a5 = a1 || temp1.size() > 2)
						  temp3.push_back(a5);
						  temps1.push_back(temp3);
					temps=temps2;
	resbuf EndTime;
	acedGetVar(_RXST("TDUSRTIMER"), &EndTime);
	ads_real UserTime;
	UserTime = 86400.0 * (EndTime.resval.rreal - StartTime.resval.rreal);
	TCHAR ChTime[50];
	acdbRToS(UserTime, 2, 8, ChTime);
	acutPrintf(_RXST("\nTime: %s \n"), ChTime);
Message 16 of 23
tbrammer
I haven't checked your code yet. What do you mean by "problem code"?
Does it solve the problem for you or does it not work as expected? Please specify.
Message 17 of 23
1127204185
			temp.push_back(a1);
			temp.push_back(a2);
				temp3.clear();
					temp1=temps.at(ii);
                      temp3=temp1;
					  if ( a5 != a4  )
					temps=temps2;
Message 18 of 23
tbrammer
In MyGroupMyCommand1 () you use a function deletePoint(dat3, 1e-7). Can you post the code?
Comments in the code would be extremely helpful to show which results you expect and where things don't work as expected.
Message 19 of 23
1127204185
//Remove duplicates  AcGePoint3d
static AcGePoint3dArray deletePoint(AcGePoint3dArray ptA,double minl)
	//AcGeTol pan;
	//pan.setEqualPoint(minl);
	if(ptA.length()>0)
		for(int i=0;i<ptA.length()-1;i++)
			for(int j=ptA.length()-1;j>i;j--)
				//if((ptA.at(i)).isEqualTo(ptA.at(j)))
				if((ptA.at(i)).distanceTo(ptA.at(j))<=minl)
					ptA.removeAt(j);
	return ptA;
Message 20 of 23
tbrammer
At first glance I only see that some for loops use wrong ranges. i.e.:
// will only iterate over dats.size()-1 entries
It makes more sense to use the AcGePoint3dArray dat4 directly instead of a map.  Simply use the array-index as point index! Note: Usually a map is filled like this:
dats[i] = dat4[i-1]; // will create an entry at key i
To understand the code better I have renamed some variables and made some changes. You find my code in the attached zip. Basically you have to code an algorithm that "walks along" all possible paths using connectedPointsIndices and finds all the shortest possible closed loops. This isn't trivial - and it's your job. Good luck!
