We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Simply assign Start/Endpoint of a Line Entity
Hello there,
Im an ARX beginner (Charles McAuley : Programming Autocad 2000 / Chapter 3).
For exercise I translate my old ADS-Applications into ARX.
I have the Problem to get the position Informations (DXF Code 10 and 11)
of a Line Entitiy without resultbuffers.
I think the answer is simple but i dont get it.
ads_point pt;
ads_name en;
acedEntSel("\nSelect an Line Entity: ",en,pt); // ! Snip Error checking ONLY
LINES !
AcGePoint3d StartingLine; // for getting the startpoint of the Line
AcGePoint3d EndingLine; // for getting the endpoint of the Line
AcDbObjectId objId; // def Object Id
acdbGetObjectId(objId,en); // get Objext Id
AcDbObject *pObj; // Pointer of type AcDbObject
acdbOpenObject(pObj, objId, AcDb ::kForRead);
???????? HOW CAN I assign
the points: StartingLine and Endingline now
pObj->Close
Thank you for helping a newbie
Dennis
Dennis,
As you have a pointer to AcDbObject you need to downcast the pointer to have
access to AcDbLine specific functions.
// First you need to cast the pointer.
// Note that as we know that AcDbLine derives from AcDbObject this cast must
work
AcDbLine* pLine = AcDbLine::cast(pObj); // Safe cast. Don't use pLine =
(AcDbLine*)pObj
// Check if cast was successful
if (pLine != NULL) {
pLine->setStartPoint(StartingLine);
pLine->setEndPoint(EndingLine);
// Now, as pLine and pObj points to the same thing, you just need to close
one of them, in this case pObj.
// Don't close pLine!
pObj->close();
Also I would recommend you to check if acdbOpenObject() was succeeded
checking its return value:
if (acdbOpenObject(...) == Acad::eOk) {
// Do all the rest inside this statement
Fernando.
"Dennis Meier" wrote in message
news:E5A8827AE7A4C7412776AE1E5E58DB86@in.WebX.maYIadrTaRb...
> Hello there,
3).
> ads_point pt;
> ads_name en;
ONLY
> LINES !
> pObj->Close
> Dennis
try this, then you'll have a pointer to a line entity.
AcDbLine *pLine; // Pointer of type AcDbLine
> acdbOpenAcDbEntity((AcDbEntity *&) pLine, objId, AcDb ::kForRead);
Joerg
Dennis Meier schrieb in im Newsbeitrag:
> Hello there,
3).
> ads_point pt;
> ads_name en;
ONLY
> LINES !
> pObj->Close
> Dennis
Just replace this:
> AcDbObject *pObj;
AcDbLine* pLine = NULL;
acdbOpenObject(pLine, objId, AcDb ::kForRead);
"Dennis Meier" az alábbiakat írta a következo üzenetben:
> Hello there,
3).
> ads_point pt;
> ads_name en;
ONLY
> LINES !
> pObj->Close
> Dennis
