setVisualStyle make no effect
Message 1 of 12
hi, community,
I want to set "Conceptual" visual style to one viewpot, but it makes no effect.
On Autocad, I find that the label on viewport change to "Conceptual", but the entities make no change, still the default style "2D wireframe".
here is my code:
void AdjustViewport(const CString& strLayout, int nIndex, const std::vector<AcDbObjectId>& vecEnt, const AcGePoint3d& modelCenter)
	AcDbViewport* pViewport = GetViewport(strLayout, nIndex);
	if (pViewport == nullptr)
		ASSERT(pViewport != nullptr);
		return;
	int nRetActiveLayout = acedCommand(RTSTR, _T("layout"), RTSTR, _T(""), RTSTR, _T("testCopy"), 0);
	ASSERT(nRetActiveLayout == RTNORM);
	acedMspace();
	Acad::ErrorStatus es = acedSetCurrentVPort(pViewport);
	ASSERT(es == Acad::eOk);
	int nSetSWISO = acedCommand(RTSTR, _T("-view"), RTSTR, _T("_swiso"), 0);
	ASSERT(nSetSWISO == RTNORM);
	ads_name ssname;
	acedSSAdd( NULL, NULL, ssname );
	GroupSelect(vecEnt, ssname);
	acedSSSetFirst( ssname, NULL );
	int nZOOM = acedCommand(
		RTSTR, _T("_ZOOM"),
		RTSTR, _T("_OBJECT"),
		RTPICKS, ssname,
		RTSTR, _T(""),
		RTNONE);
	ASSERT(nZOOM == RTNORM);
	acedSSFree(ssname);
	acedSSSetFirst( NULL, NULL );
	AcDbObjectId vsId = AcDbObjectId::kNull;
	AcDbDictionaryPointer pNOD(acdbHostApplicationServices()->workingDatabase()->visualStyleDictionaryId(), AcDb::kForRead);
	pNOD->getAt(ACRX_T("Conceptual"), vsId);
	Acad::ErrorStatus esSetVS = pViewport->setVisualStyle(vsId);
	ASSERT(esSetVS == Acad::eOk);
	//SetVisualStyle(vecEnt);
	pViewport->updateDisplay();
	pNOD->close();
	pViewport->close();
pls help, thx!
Replies (11)
Message 2 of 12
tbrammer
Please try to call   pNOD->close();
before            pViewport->setVisualStyle(vsId);
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 12
hi, tbrammer
I try your suggestion, but it still not work.
Anyway, I set visual style directly in my template dwg file.
thx,
nolan
Message 4 of 12
tbrammer
Do you mean that the viewport doesn't show up with the new visual style?
Maybe some graphics refresh is required.
You could try  ads_regen() and/or
AcTransactionManager *pAcTransactionManager=actrTransactionManager;
if (pAcTransactionManager)
   pAcTransactionManager->queueForGraphicsFlush();
   pAcTransactionManager->flushGraphics();
acedUpdateDisplay();
Message 5 of 12
I don't know whether is vs2010 can't find  ads_regen(), so I can't try this.
And I try actrTransactionManager, but it alse makes no effect, somewhat disappointed.
but, thanks all the same.
Message 6 of 12
Alexander.Rivilis
You can use ads_regen in all AutoCAD versions since 2000.
With AutoCAD 2014 you have to add next definition (as far as this function is not documented and is not defined in any of .h-files):
void ads_regen(void);
Also you have to link with accore.lib
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 7 of 12
tbrammer
@Alexander.Rivilis: Could you suggest the ARX Dev team to add ads_regen() to the ARX headers and docs? Or are there any reasons to "hide" this quite important function?
Message 8 of 12
Alexander.Rivilis
Dear @artc2 !
I hope you can explain why ads_regen is not documented and not added in any of .h-file within ObjectARX SDK since AutoCAD 2000.
Please!
Expert Elite Member
Message 9 of 12
tbrammer
The same topic is dicussed here.
Here 's the solution I just found and postet there:
If you switch from "2D wireframe" to a 3D visual style, an AcGsView needs to be created. This code works for AutoCAD 2018:
//Need AcDrawBridge.lib for AcGsKernelDescriptor::k3DDrawing
#pragma comment(lib, "AcDrawBridge.lib")
void SetVisualStyle(AcDbObjectId idVP) { Acad::ErrorStatus es; AcDbObjectId vsId = AcDbObjectId::kNull; AcDbDictionaryPointer pNOD(acdbHostApplicationServices()->workingDatabase()->visualStyleDictionaryId(), AcDb::kForRead); pNOD->getAt(ACRX_T("Conceptual"), vsId); int vpNum = -1; AcDbViewport *pViewport; if ((es = acdbOpenObject(pViewport, idVP, AcDb::kForWrite)) == Acad::eOk) { vpNum = pViewport->number(); pViewport->setVisualStyle(vsId); pViewport->close(); } AcGsView *pView = acgsGetCurrent3dAcGsView(vpNum); if (!pView) { AcGsKernelDescriptor gsKernel; gsKernel.addSupport(AcGsKernelDescriptor::k3DDrawing); pView = acgsObtainAcGsView(vpNum, gsKernel); // create if necessary. } if (pView) pView->show(); void ads_regen(); ads_regen(); }
Message 10 of 12
artc2
It's not documented nor in any public header file because it was never intended for anything other than very specific purposes in AutoCAD internal code and has not been tested for general use.
Message 11 of 12
Alexander.Rivilis
Thank for explanation! So this function internal is very different with _REGEN command? I've used this function many years instead of _REGEN in order to prevent using command methods.
Expert Elite Member
Message 12 of 12
artc2
No, ads_regen() and the REGEN command are fairly similar, but they are not exactly the same. The primary difference is that the code path for the REGEN command will only work in a command context whereas ads_regen() does not have that requirement.
