Reg:Error MSB8008: Specified platform toolset (v140) is not installed or invalid
nathan307
Message 1 of 23
nathan307
Dear Friends,
I try to compile sample VC++ projects in the AutoCAD Plant 3D SDK(For 2017).
And I got an error MSB8008: Specified platform toolset (v140) is not installed or invalid.
I got this error for all (C++) samples of AutoCAD Plant 3D SDK(For 2017).
I am using Visual studio 2015.and Autocad P&ID 2017.
I try to change platform toolset to Visual Studio 2012 (v110) From .But the problem is not solved.
My current Platform toolset is Visual Studio 2015 (v140).Because im working with AutoCAD P&ID 2017.
How to solve this problem.please give your suggestion.
Note that:
I downloaded AutoCAD Plant 3D SDK(For 2017) From the below Link
http://www.autodesk.in/adsk/servlet/index?siteID=123112&id=15460551
Thank you Friends,
Nathan.
Replies (22)
Message 21 of 23
Alexander.Rivilis
Oops! Not PnIDObjects.lib but PnP3dObjects.lib
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 22 of 23
nathan307
Dear Friend,
Thank you for Your Suggestion.
It Works fine now.
Thanks&Regards
Nathan
Message 23 of 23
Alexander.Rivilis
There are useful buttons "Accept as Solution" and "Kudo" on forum. 🙂
Expert Elite Member
