Reference vector of AcDbArc
Hello!
I am trying to get the reference vector of a circular arc.
The only information I found is:
AcDbArc* arc = AcDbArc::cast( pEnt );
AcGeVector3d refVec = arc->normal()->perpVector();
However, I was expecting a method to give back the reference vector.
Could somebody help me?
Kind regards,
Evangelos
In the end I computed the Arbitrary X axis based on the following article:
https://help.autodesk.com/view/OARX/2018/ENU/?guid=GUID-E19E5B42-0CC7-4EBA-B29F-5E1D595149EE
Now, I am not facing any problems with my arcs.
However, I am still curious to know why there is not a method to compute it directly?
Evangelos
tbrammer
AcGeVector3d::perpVector() also uses the arbitrary axis algorithm. This is the usual way to determine the reference vector.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Dear tbammer,
Thank you very much for your reply.
I always need to use the OCS X axis as the reference vector. So, I created a small function to compute it, based on the documentation:
If (abs (Nx) < 1/64) and (abs (Ny) < 1/64) then
     Ax = Wy X N (where X is the cross-product operator).
Otherwise,
     Ax = Wz X N.
To clarify, I would like to ask: Nx and Ny are the coordinates of normal N?
The perpVector indeed returns a reference vector but not the one I need.
Kind regards,
Evangelos
tbrammer
Yes. N is the normal (Nx,Ny,Nz). N must be normalized to a length of 1 if you use your algorithm.
This algorithm is the "Arbitrary Axis Algorithm". It is used by N.perpVector(). Note that perpVector() does not require N to be normalized.
What do you mean by "the returned vector is not the reference vector that you need"? What is wrong with it?
Can you post a sample DWG and your code to clarify?
Perhaps I misunderstood the documentation.
What you are saying is that the perVector of a normal vector will return the OCS X axis?
tbrammer
Yes. See also the docs for AcDbArx::startAngle()
