readBlockEntities (block within block)
1127204185
1127204185
	static void readBlockEntities(const AcDbObjectId& blkid , AcDbObjectIdArray &ids)
		AcDbBlockTableRecordIterator* iter;
		AcDbBlockReference* pBlkRef;
		AcDbBlockTableRecord* pRecord;
		Acad::ErrorStatus es = acdbOpenObject(pBlkRef, blkid, AcDb::kForRead);
		if (es != Acad::eOk)
			return;
		AcDbObjectId blockTableRecordId = pBlkRef->blockTableRecord();
		AcGeMatrix3d blkmat = pBlkRef->blockTransform();
		pBlkRef->close();
		es = acdbOpenObject(pRecord, blockTableRecordId, AcDb::kForWrite);
		if (es != Acad::eOk || pRecord == NULL)
			return;
		pRecord->newIterator(iter);
		for (iter->start(); !iter->done(); iter->step())
			AcDbObjectId id;
			AcDbEntity* pEnt1 = NULL;
			es = iter->getEntityId(id);
			es = iter->getEntity(pEnt1, AcDb::kForRead);
			if (es != Acad::eOk || !id.isValid())continue;
			AcDbObjectPointer<AcDbBlockReference> pEnt(id, AcDb::kForRead);
			if (pEnt.openStatus() == Acad::eOk)
				pEnt1->close();
				AcDbObjectIdArray nestedIds;
				readBlockEntities(id, nestedIds);
				ids.append(nestedIds);
			else
				pEnt1->transformBy(blkmat);
				ids.append(id);
				pEnt1->close();
		delete iter;
		pRecord->close();
tbrammer
It seems that you try to "explode" a blockreference (BREF) with the ID blkid and collect the fragments in AcDbObjectIdArray &ids.
The idea to treat block references by recursion is basically right. But the way you implemented it has several issues.
  1. You are opening the entities twice in two different ways, which is neither elegant nor performant.
    Better use
      AcDbBlockReference *pEnt = AcDbBlockReference::cast(pEnt1);
    pEnt will be NULL if  pEnt1 is not a block reference.
  2. You open pEnt1  for read only and try to modify it with pEnt1->transformBy(blkmat);
    1. This will crash AutoCAD. You must open the entity kForWrite.
    2. Even if you open the entity for write: Transforming it is probably not what you want, because it will modify the BREF's block itself and all it's nested blocks! The final array ids would contain ids of entities from different blocks which is pretty useless. At this point the question is: What do you expect as result?
      Usually you would create a transformed copy i.e. with
         pEnt1->getTransformedCopy(blkmat, pEntCopy);
      and append it to a block record - maybe to modelspace.
  3. When you find an AcDbBlockReference you and you call readBlockEntities() recursive you must pass the current transformation matrix blkmat and multiply the transformation matrix with the "owner matrix".
    This would look like this:
    void readBlockEntities(const AcGeMatrix3d &matOwner, ..)
      AcGeMatrix3d blkmat = matOwner * pBlkRef->blockTransform();
      if (pBref)
        readBlockEntities(blkmat, id, nestedIds);
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Thank you very much! I have studied your 'explain' code,The modification was not successful,I feel like this is more difficult。I have been unable to complete it。
tbrammer
Try this:
void readBlockEntities(const AcGeMatrix3d& matOwner, AcDbBlockReference *pBlkRef, AcDbBlockTableRecord *pTargetBlock, AcDbObjectIdArray& ids)
	if (!pBlkRef || !pTargetBlock)
		return;
	Acad::ErrorStatus es;
	pBlkRef->close();
	es = acdbOpenObject(pRecord, blockTableRecordId, AcDb::kForRead); //TB only for read. We don't want to modify the block.
	if (es != Acad::eOk || !pRecord)
		return;
			continue;
		AcDbBlockReference* pSubBref = AcDbBlockReference::cast(pEnt1);
		if (pSubBref)
			readBlockEntities(blkmat, pSubBref, pTargetBlock, nestedIds);
		else
			AcDbEntity *pNewEnt=nullptr;
			es = pEnt1->getTransformedCopy(blkmat, pNewEnt);
			if (!es)
				es = pTargetBlock->appendAcDbEntity(pNewEnt);
				if (es)
					delete pNewEnt;
				else
					ids.append(pNewEnt->objectId());
					pNewEnt->close();
		pEnt1->close();
	delete iter;
	pRecord->close();
void readBlockEntities(const AcDbObjectId& blkid, AcDbObjectIdArray& ids)
	if (es)
		acutPrintf(L"\nNot a BREF!");
		return;
	// We want to append the enties to the modelspace...
	AcDbDatabase *db = pBlkRef->database();
	AcDbObjectId IdModelSpace = acdbSymUtil()->blockModelSpaceId(db);
	AcDbBlockTableRecord *pModelSpace;
	if ((es = acdbOpenObject(pModelSpace, IdModelSpace, AcDb::kForWrite)) == Acad::eOk)
		AcGeMatrix3d mat;
		mat.setToTranslation(AcGeVector3d(200.0, 0.0, 0.0)); // ... translated by 200 in X direction.
		readBlockEntities(mat, pBlkRef, pModelSpace, ids);
		pModelSpace->close();
void cmdTestReadBlockEntities()
	ads_point    pt;
	ads_name     ent;
	AcDbObjectId blkid;
	if (acedEntSel(_T("\nPick a BREF: "), ent, pt) != RTNORM)
		return;
	if (acdbGetObjectId(blkid, ent) != Acad::eOk)
		return;
	AcDbObjectIdArray ids;
	readBlockEntities(blkid, ids);
