Problem in Debug
Problem in Debug
Problem in Debug
I had problem in Debug mode. In release mode is working fine. when i try go Debug mode. it is showing message like
"Windows has triggered a breakpoint in acad.exe."
"This may be due to a corruption of the heap, and indicates a bug in acad.exe or any of the DLLs it has loaded."
"The output window may have more diagnostic information"
In my project Main Arx will load two dbx files and three Arx file. first i am loading two dbx files first one dbx file is loading fine and second dbx file (this) is using first dbx Object file library .
This Debug mode is working fine for first dbx file. After loading the second dbx file, Debug mode is not working this second dbx file and remaining Arx file.
i think problems is in second dbx file. I am unable to find problem.
please see the bmp file of error message.
Sankar.M
One of the DBX files loads the other? Are they all compiled in debug mode?
At what point does it actually throw that error? Is it on an acrxLoadModule
call for the DBX, or is it sometime later? Have you tried just loading the
offending module by itself, from an essentially empty ARX?
Though i can't specifically tell what's happening, one of the best pieces of
advice i can give is to simplify. If a module isn't loading correctly, and
you can't seem to figure out why, copy the project and gut it to the bare
minimum. Once you've got it loading, start adding pieces back in until you
get the error. Clearly, this can be a time consuming process - but if
you've exhausted all other options, this is something to try.
-Rich
wrote in message news:5493907@discussion.autodesk.com...
remaining Arx file.
Sankar.M
