Precision of getSplitCurves
Message 1 of 9
Hi!
I am using getSplitCurves on a small arc (0.00021807) with a splitpoint very close to the start point (distance is 0.0000084). It returns Acad::eOK, but the length of the returned array is only 1, so the arc isn't really split.
If I run mapclean from Autocad Map on this, it is able to split the arc properly.
Is there some global presicision setting in ObjectArx? Or does Autodesk have their own internal routines with more precision, which are not exposed through ObjectArx?
I hate the idea of rewriting getSplitCurves...
Thanks for any help!
Replies (8)
Message 2 of 9
kubitTilo
You may try setting AcGeContext::gTol.setEqualPoint(...) to a higher than the default value, which is 1e-10 I think.
Don't forget to save and restore the original value before and after your operations 😉
Tilo Pfliegner
Message 3 of 9
Excellent! This value was 5E-05 as default, that's why it considered a line of a little less than that as uninteresting.
After setting it to 1E-10 it worked like a charm.
Thank you very much, this was an extremely quick and precise answer and something that wasn't easy to find when you don't know where to look!
Best regards,
Knut
Message 4 of 9
I recall getting something similar with small length entities, what i did was to use the boundingbox or extents of the entities and then do a crossing selection, get the intersection points, sort these points, on polylines i always checked the type if not were AcDb::k2dSimplePoly, i converted to a temp light weight poly in order (in my case as far i remember) to make my SplitCurves command to work.
Here is some partial code from my function - hth:
	for (UINT i = 0; i < length1; i++)
		AcDbObjectId oid;
		ads_name ename;
		acedSSName(ss1, i, ename);
		if (acdbGetObjectId(oid, ename) != Acad::eOk) return;
		AcDbObjectPointer<AcDbCurve> pPoly(oid, AcDb::kForWrite);
		if (pPoly.openStatus() == Acad::eOk)
			ids.append(oid); // for erase
			AcDbExtents ebox;
			pPoly->getGeomExtents(ebox);
			AcGePoint3d ll, ur;
			ll = ebox.minPoint();
			ur = ebox.maxPoint();
			acdbWcs2Ucs(asDblArray(ll), asDblArray(ll), false);
			acdbWcs2Ucs(asDblArray(ur), asDblArray(ur), false);
			ads_point ptres, a, b;
			AcGePoint3d m;
			double d = (sqrt(2.0) * acutDistance(asDblArray(ll), asDblArray(ur)) / 2.0);
			acutPolar(asDblArray(ll), acutAngle(asDblArray(ll), asDblArray(ur)), acutDistance(asDblArray(ll), asDblArray(ur)), asDblArray(m));
			acutPolar(asDblArray(m), ((3 * kPi) / 4), d, ptres);
			acdbWcs2Ucs(ptres, a, false);
			acutPolar(asDblArray(m), ((7 * kPi) / 4), d, ptres);
			acdbWcs2Ucs(ptres, b, false);
			ads_name ss2;
			resbuf *rbFilter = acutBuildList(RTDXF0, _T("LINE,ARC,LWPOLYLINE,POLYLINE,CIRCLE,SPLINE,ELLIPSE"), RTNONE);
			if (acedSSGet(_T("_C"), asDblArray(ll), asDblArray(ur), rbFilter, ss2) != RTNORM)
			//if (acedSSGet(_T("_C"), a, b, rbFilter, ss2) != RTNORM)
				acutRelRb(rbFilter);
				return;
			acedSSDel(ename, ss2);
 I tested with a arc of the same length and the same split distance, and works here.
Message 5 of 9
Thanks for trying, but I don't really see what you do here. There is nothing created, only a lot of calculation?
Anyway, I got a great solution already!
Message 6 of 9
Glad you got a solution and yes i realize that, here is my old code, in case someone finds it useful.
typedef std::vector<AcGePoint3d> PointList;
const double kPi = 3.14159265358979323846;
Acad::ErrorStatus MakeTempLWPoly (AcDb2dPolyline* tmp2dPoly, AcGePoint3dArray &pts, AcDbVoidPtrArray &curveSegments)
	Acad::ErrorStatus es;
	AcDbObjectId curSpaceId = acdbCurDwg()->currentSpaceId();
	AcDbBlockTableRecord *pBlkRec = NULL;
	AcDbCurve* tmpCurve;
	AcGePoint3dArray vertices;
	AcGeDoubleArray bulges;
	AcDb2dVertex* vert = NULL;
	AcDbObjectId vId;
	double c = 0;
	AcDbObjectIterator *vIter;
	double parametro;
	vIter = tmp2dPoly->vertexIterator();
	for (; !vIter->done(); vIter->step())
		vId = vIter->objectId();
		if (tmp2dPoly->openVertex(vert, vId, AcDb::kForRead) == Acad::eOk)
			if (tmp2dPoly->getParamAtPoint(vert->position(), parametro) == Acad::eOk)
				c = vert->bulge();
				if ((tmp2dPoly->normal()-AcGeVector3d::kZAxis).length() > 1E-6) c *= -1.0;
				vertices.append(tmp2dPoly->vertexPosition(*vert));
				bulges.append(c);
			vert->close();
	if (tmp2dPoly->isClosed())
		if (vertices.first() != vertices.last())
			vertices.append(vertices.first());
			bulges.append(bulges.first());
	delete vIter;
	Adesk::Boolean closed;
		closed = Adesk::kTrue;
	else
		closed = Adesk::kFalse;
	AcCmColor col = tmp2dPoly->color();
	ACHAR* ltype = tmp2dPoly->linetype();
	AcDbPolyline* pBreakLine = new AcDbPolyline(vertices.length());
	for (int i=0; i < vertices.length(); i++)
		AcGePoint2d pt;
		pt.set(vertices.at(i).x,vertices.at(i).y);
		pBreakLine->addVertexAt(i,pt,bulges.at(i));
	pBreakLine->setClosed(closed);
	pBreakLine->setColor(col);
	pBreakLine->setLinetype(ltype);
	acutDelString(ltype);
	vertices.removeAll();
	bulges.removeAll();
	es = pBreakLine->getSplitCurves(pts,curveSegments);
	if (es == Acad::eOk)
		for (int i=0; i < curveSegments.length(); i++)
			tmpCurve = static_cast<AcDbCurve*>(curveSegments[i]);
			if (tmpCurve)
				if (acdbOpenObject(pBlkRec,curSpaceId,AcDb::kForWrite) == Acad::eOk)
					pBlkRec->appendAcDbEntity(tmpCurve);
					pBlkRec->close();
					tmpCurve->close();
		curveSegments.removeAll();
	else
		for (int i = 0; i < curveSegments.length(); i++)
			delete tmpCurve;
	pBreakLine->close();
	delete pBreakLine;
	return es;
static void SplitCurves (void)
	AcGePoint3dArray pts;
	AcDbVoidPtrArray curveSegments;
	AcGePoint3dArray ints;
	AcGePoint3dArray duplicates;
	PointList points;
	ads_name ss1;
	AcDbObjectIdArray ids;
	if (acedSSGet(NULL, NULL, NULL, rbFilter, ss1) != RTNORM)
		return;
	long length1 = 0;
	if ((acedSSLength(ss1, &length1) != RTNORM) || (length1 == 0))
		acedSSFree(ss1);
		return;
		AcDbObjectId oid;
		ads_name ename;
			ids.append(oid);
			AcDbExtents ebox;
			AcGePoint3d ll, ur;
			AcGePoint3d m;
			ads_name ss2;
				return;
			long length2 = 0;
			if ((acedSSLength(ss2, &length2) != RTNORM) || (length2 == 0))
				acedSSFree(ss2);
				return;
			for (UINT i = 0; i < length2; i++)
				AcDbObjectId oid;
				ads_name ename;
				acedSSName(ss2, i, ename);
				AcDbObjectPointer<AcDbCurve> pEnt(oid, AcDb::kForRead);
				if (pEnt.openStatus() == Acad::eOk)
					if (pPoly->intersectWith(pEnt.object(), AcDb::kOnBothOperands, ints) == Acad::eOk)
						if (!ints.isEmpty())
							for (UINT i = 0; i < ints.length(); i++)
								if (!duplicates.contains(ints.at(i)))
									duplicates.append(ints.at(i));
									points.push_back(ints.at(i));
								else
									continue;
			acedSSFree(ss2);
			if (!points.empty())
				vector<double> distances;
				map<double, AcGePoint3d> m;
				double dist;
				for (UINT i = 0; i < points.size(); i++)
					AcGePoint3d pt = points.at(i);
					if (pPoly->getDistAtPoint(pt, dist) == Acad::eOk)
						m.insert(make_pair(dist, pt));
						distances.push_back(dist);
				map<double, AcGePoint3d>::const_iterator it;
				int cnt = 0;
				std::sort(distances.begin(), distances.end());
				std::vector<AcGePoint3d> _points;
				for (it = m.begin(); it != m.end(); ++it)
					AcGePoint3d pt;
					it = m.find(distances.at(cnt));
					pt = (*it).second;
					_points.push_back(pt);
					cnt = (1 + cnt);
				m.clear();
				distances.clear();
				for (UINT i = 0; i < _points.size(); i++)
					AcGePoint3d pt;
					pt = _points.at(i);
					acdbWcs2Ucs(asDblArray(pt), asDblArray(pt), false);
					pts.append(pt);
				if (pPoly->isKindOf(AcDb2dPolyline::desc()))
					AcDb2dPolyline *tmp2dPoly = AcDb2dPolyline::cast((AcRxObject*)pPoly.object());
					switch (tmp2dPoly->polyType())
					case AcDb::k2dSimplePoly:
						if (pPoly->getSplitCurves(pts, curveSegments) == Acad::eOk)
							for (UINT i = 0; i < curveSegments.length(); i++)
								if (tmpCurve)
									if (acdbOpenObject(pBlkRec, curSpaceId, AcDb::kForWrite) == Acad::eOk)
										pBlkRec->close();
										tmpCurve->close();
						else
								delete tmpCurve;
						break;
					case AcDb::k2dFitCurvePoly:
						MakeTempLWPoly(tmp2dPoly, pts, curveSegments);
						break;
					case AcDb::k2dQuadSplinePoly:
						break;
					case AcDb::k2dCubicSplinePoly:
						break;
				else
							if (tmpCurve)
									pBlkRec->close();
									tmpCurve->close();
					else
							delete tmpCurve;
				_points.clear();
				points.clear();
				ints.removeAll();
			if (!duplicates.isEmpty())
				duplicates.removeAll();
			if (!curveSegments.isEmpty())
			if (!pts.isEmpty())
				pts.removeAll();
	acedSSFree(ss1);
	if (!ids.isEmpty())
		for (UINT i = 0; i < ids.length(); i++)
			AcDbObjectPointer<AcDbEntity> pEnt(ids[i], AcDb::kForWrite);
				pEnt->erase();
		ids.removeAll();
 Also, a simple version in C#:
#region Split Curves
[CommandMethod("SPLITCURVES")]
public void cmd_splitCurves()
    var editor = AcadApp.DocumentManager.MdiActiveDocument.Editor;
    var tv = new[] { new TypedValue((int)DxfCode.Start, "LINE,ARC,LWPOLYLINE,POLYLINE,CIRCLE,SPLINE,ELLIPSE") };
    var filter = new SelectionFilter(tv);
    const string curveObjects = "curve objects";
    var options = new PromptSelectionOptions
        MessageForAdding = string.Format("\nAdd {0} to selection", curveObjects),
        MessageForRemoval = string.Format("\nRemove {0} from selection", curveObjects),
        AllowDuplicates = false,
        RejectObjectsFromNonCurrentSpace = true
    var mainSelection = editor.GetSelection(options, filter);
    if (mainSelection.Status != PromptStatus.OK) return;
    using (var transaction = editor.Document.Database.TransactionManager.StartTransaction())
        var blockTableRecord = transaction.GetObject(editor.Document.Database.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
        if (blockTableRecord != null)
            foreach (var mainObjectId in mainSelection.Value.GetObjectIds())
                var points = new Point3dCollection();
                var dictionary = new SortedDictionary<double, Point3d>();
                var mainCurve = transaction.GetObject(mainObjectId, OpenMode.ForWrite) as Curve;
                if (mainCurve == null) continue;
                var extents = mainCurve.GeometricExtents;
                var minPoint = extents.MinPoint;
                var maxPoint = extents.MaxPoint;
                var subSelection = editor.SelectCrossingWindow(minPoint, maxPoint, filter);
                if (subSelection.Status != PromptStatus.OK) continue;
                foreach (var subObjectId in subSelection.Value.GetObjectIds())
                    var subCurve = transaction.GetObject(subObjectId, OpenMode.ForRead) as Curve;
                    if (subCurve == null) continue;
                    var intersections = new Point3dCollection();
                    mainCurve.IntersectWith(subCurve, Intersect.OnBothOperands, intersections, IntPtr.Zero, IntPtr.Zero);
                    if (intersections.Count <= 0) continue;
                    foreach (Point3d intersection in intersections)
                        if (points.Contains(intersection)) continue;
                        points.Add(intersection);
                subSelection.Value.Dispose();
                if (points.Count <= 0) continue;
                foreach (Point3d point in points)
                    var distance = mainCurve.GetDistAtPoint(point);
                    if (dictionary.ContainsKey(distance)) continue;
                    dictionary.Add(distance, point);
                if (!dictionary.Any()) continue;
                var splitPoints = new Point3dCollection(dictionary.Values.ToArray());
                var splitCurves = mainCurve.GetSplitCurves(splitPoints);
                foreach (DBObject splitCurve in splitCurves)
                    var curve = splitCurve as Curve;
                    if (curve == null) continue;
                    blockTableRecord.AppendEntity(curve);
                    transaction.AddNewlyCreatedDBObject(curve, true);
        transaction.Commit();
#endregion
 HTH.
Message 7 of 9
On any of my possible replies with code on these customization forums, i need to figure out how the insert-code works, so far what i see as a result is not good, is this how it works or displayed on this site?
Message 8 of 9
Seems like all your code was included this time. I'll look at it in 4-5 hours.
Message 9 of 9
Sorry, but I didnt' really see what you achieve with this code, LE3. And the gtol trick worked for now, so I'll let it be like that.
Thank you anyway!
