ObjectArx / Dbx crashes in debug build.
I have just started a project, a single arx dll and a single dbx dll. Both only implement an application class, no commands, no custom entities, no dialogs etc... When I attempt to load the dbx and arx applications in debug build, I get a crash:
Unhandled exception at 0x000007fefd5acaed (KernelBase.dll) in acad.exe: 0x804F4C45: 0x804f4c45.
Visual Studio 2010
ObjectArx 2012
AutoCAD 2012 (64 bit)
Any hints. Note, as stated above, there is nothing in these projects other than the application classes providing the entry points.
I have attached a zip containing the projects. In each contains a single class that I have created. InFormArxApp and InFormDbxApp.
Mike
Further, if I only load the arx or dbx application alone, the crash does not occur. If I load the both the DBX and the ARX the crash occures.
Mike
owenwengerd
You should show the line(s) of code where the exception occurs, and what the problem is at that point that caused the exception.
Owen Wengerd
ManuSoft
Well I was hoping to get this resolved but the crashing has seemed to resolve itself. I haven't changed anything in that code so I am not sure what the problem is/was.
Mike
