ObjectARX 2024 Wizards
MGO-Norsyn
Message 1 of 14
MGO-Norsyn
Hi all
How to make the ObjectArx wizards work in VS 22?
I have searched everywhere and also employed help of ChatGPT to no avail.
The best post recommends installing with admin rights, but still doesn't work.
Anyone has got it working?
Replies (13)
Message 2 of 14
crossfire639buy
Place you ObjectARX files exactly like that: "С:\ObjectARX". Also put a wizard .msi file there and run it from the administrator command line. That should help!
Message 3 of 14
MGO-Norsyn
Ooooookay, actually putting the wizard .msi in the C:\ObjectARX folder and installing from there using admin cmd worked. Maybe also a restart helped. Thank you.
Message 4 of 14
MGO-Norsyn
Argh, it worked on my company machine, but doesn't work on my laptop!
Message 5 of 14
MGO-Norsyn
Works after a lot of installing/reinstalling.
Message 6 of 14
08130182
Sorry, where I have the objectarx wizard 'Arx Wizards.msi', I have not been able to configure VS2022 with Objetarx, if you can share the download link please, thanks in advance.
Perdona, donde tengo el asistente de objectarx 'Arx Wizards.msi', no he podido configurar VS2022 con Objetarx, si me puedes compartir el enlace de descarga por favor, gracias de antemano.
Message 7 of 14
MGO-Norsyn
Here you go
Message 8 of 14
Alexander.Rivilis
https://damassets.autodesk.net/content/dam/autodesk/files/objectarxwizard2024.zip
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 9 of 14
mladenovicnikola47
Community Visitor
Community Visitor
Hi all,
I have been attempting to set up the ObjectARX project for AutoCAD 2024 template in my Visual Studio 2022 environment.
I followed the steps outlined below:
  • Installed the VS 2022 Community Edition.
  • Installed AutoCAD 2024.
  • Installed ObjectARX for AutoCAD 2024 from link.
  • Installed ObjectARXWizard2024.msi from this thread.
I have also attempted to install/reinstall the Object ARX Wizard multiple times. Additionally, I tried storing all files in the C:\ObjectARX folder. However, every time I open Visual Studio 2022, the ObjectARX template is not visible in its templates.
Do any of you know how I can overcome this obstacle?
I would also like to mention that I have installed AutoCAD 2021 and Visual Studio 2019. Could these installations possibly be affecting my issue?
Message 10 of 14
Alexander.Rivilis
ObjectARX Wizard have to be installed with Administrator rights.
Expert Elite Member
Message 11 of 14
mladenovicnikola47
Community Visitor
Community Visitor
Also, I have run Wizard.msi from CMD(open CMD as Admin, redirect to C:\ObjectARX folder and run Wizard.msi).
It not help me
Message 12 of 14
835700012
https://blog.csdn.net/miaodichiyou/article/details/131470765
try to modify some files follow this atricle
may be is it helpfull
Message 13 of 14
OysteinW
If you came  in here looking to get ObjectArx Wizards for AutoCAD 2025 working, install the wizard as described by @crossfire639buy
But if it still is not working, as was the case for me, I actually got it working with a little help from ChatGPT:
To make the ObjectARX project templates available in Visual Studio 2022, you may need to manually register the templates. Here's how you can do it:
  1. Copy the Project Templates:
    • Copy the contents of the C:\Program Files (x86)\Autodesk\ObjectARX 2025\utils\ARXWizards\ARXAppWiz directory to the Visual Studio project templates directory.
    • Paste them into the following location:
      makefile
      C:\Program Files\Microsoft Visual Studio\2022\Enterprise\Common7\IDE\ProjectTemplates
  2. Run devenv command to update the templates:
    • Open a Command Prompt as an Administrator.
    • Run the following commands to update the Visual Studio template cache:
      shell
      cd "C:\Program Files\Microsoft Visual Studio\2022\Enterprise\Common7\IDE" devenv /installvstemplates
  3. Verify Installation:
    • Open Visual Studio 2022.
    • Create a new project and check if the ObjectARX templates are now listed under the project templates.
These steps should ensure that the ObjectARX project templates are registered and available for use in Visual Studio 2022. If you encounter any issues, please make sure that you have the correct permissions and that the paths are accurate.
Message 14 of 14
quzeyu
Community Visitor
Community Visitor
It's need .Net4.8 in window system, I have do same step as you, it didn't show in VS 2022, then i install net4.8 from vs2022 installer, the arx wizards show in templete window.
