mysql, c++, arx
mysql, c++, arx
mysql, c++, arx
I am trying to integrate my drawing package (arx) with mysql in realtime.
As of now I store a lot of data in attributes. This can make the drawing
files very large. Does anybody know of a way to connect to a mysql database
with vc++ 7.0.
Any help is greatly appreciated.
Thanks in advance.
Rob
This is the code I am currently working with.
I can connect the database but I get errors when I try to query the
database:
size=2>
CString ConnectionString;
ConnectionString = "ODBC;DRIVER={MySQL ODBC 3.51
Driver};SERVER=localhost;DATABASE=dccad;USER=root;DSN=myodbc3-test;";
try //connect to the
DataManager
color=#0000ff>if
(DataManager.Open(ConnectionString))
dc_log(logfile,"\nDataManager opened
successfully.");
catch(CDBException *pe)
//catch database errors
dc_log(logfile,"Database Error:
%s",pe->m_strError);
pe->Delete();
//now get the types
CRecordset rsTypes(&DataManager);
CString fieldname,convdesc,SQLText;
SQLText="\"SELECT type,description FROM
tabletype;\"";
dc_log(logfile,"SQLText =
%s",SQLText);
try
size=2>rsTypes.Open(CRecordset::snapshot,(SQLText));
dc_log(logfile, "QUERY OPENED
SUCCESSFULLY");
color=#0000ff>while
(!rsTypes.IsEOF())
rsTypes.GetFieldValue(0,fieldname);
rsTypes.GetFieldValue(4,convdesc);
dc_log(logfile,"\nType: %s -
%s",fieldname,convdesc);
rsTypes.MoveNext();
catch (CDBException
*pe)
dc_log(logfile,"Query Error:
pe->Delete();
Could there be problem with your SQLText. Why do
you need to include enclosing doubleQuote (the characters \") and why do you
have semicolon at the end? Should it be:
SQLText="SELECT type,description FROM tabletype";
If MySQL's ODBC complies with ODBC standard,
then the format of the SQL statement should be the same with other
database-ODBC's SQL statement. I have never used MySQL so I could be
wrong.
OutlookExpress' Question:
   If I want my reply to be in plainText,
what do I need to do? Rob's posting is in HTML, but I want my reply in
plainText.
Joseph
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
with.  I can connect the database but I get errors when I try to query
the database:
size=2>
DataManager
color=#0000ff>if
successfully.");
catch(CDBException
*pe) //catch database errors
pe->Delete();
//now get the types
CRecordset
tabletype;\"";
%s",SQLText);
try
SUCCESSFULLY");
color=#0000ff>while
(!rsTypes.IsEOF())
rsTypes.MoveNext();
catch (CDBException
*pe)
pe->Delete();
Joseph,
I have tried many different syntaxes for the
sql. I even tried to enclose tabletype in single quotes as if it were a
string value.  When I do that I get an error logged to the file to check my
sql, so I know that I am connected to the sql server.
This is the error I get with my code: (from the log
file)
    DataManager opened
successfully.
    SQLText = "SELECT Type, Description FROM
tabletype;"
    Query Error: Attempt to open a table failed -
there were no columns to retrieve
    were
specified.
When I change the sytnax of the SQL I still get the
error but it seems that I am
not catching the CDBException
error......here is the log:
    DataManager opened
successfully.
    SQLText = SELECT Type, Description FROM
tabletype
    Query Error:
wrong.
plainText, what do I need to do? Rob's posting is in HTML, but I want my reply
in plainText.
Joseph
the database:
size=2>
3.51
DataManager
color=#0000ff>if
successfully.");
catch(CDBException
pe->Delete();
//now get the types
CRecordset
CString
tabletype;\"";
%s",SQLText);
try
SUCCESSFULLY");
color=#0000ff>while
(!rsTypes.IsEOF())
size=2>rsTypes.GetFieldValue(0,fieldname);
rsTypes.MoveNext();
catch (CDBException
*pe)
pe->Delete();
size=2>}
Rob,
  After rereading your original posting, you
said you are using VC++7. I have never used VC++7 so I don't think I might be
any help to you.
Just trying my best to help here. Why did you
mention " ... I am connected to the sql server...". Are you trying to
connect to MySQL or Microsoft SQLServer? Your ODBC driver you used in your code
is for MySQL.
CRecordSet throws 2 exception objects. Can you try
to catch the other one and check the description?
Are you sure you are connecting to the database you
intended? and If yes, does your database has the table and the columns mentioned
in your SQL statement?
Can you try using your original SQLStatement, but
delete the semicolon after string tabletype?
Can you also try SELECT * FROM
tabletype?
According to my MSDN Help, CRecordSet::Open(), it
said that no whitespace is allowed before the keyword SELECT.
Joseph
Joseph,
my sql, so I know that I am connected to the sql server.
log file)
    DataManager opened
successfully.
tabletype;"
- there were no columns to retrieve
    were
specified.
the error but it seems that I am
    DataManager opened
successfully.
tabletype
    Query Error:
do you need to include enclosing doubleQuote (the characters \") and why do
you have semicolon at the end? Should it be:
standard, then the format of the SQL statement should be the same with other
wrong.
reply in plainText.
Joseph
query the database:
size=2>
3.51
DataManager
color=#0000ff>if
successfully.");
catch(CDBException
pe->Delete();
//now get the
types
CRecordset
CString
tabletype;\"";
%s",SQLText);
try
SUCCESSFULLY");
color=#0000ff>while
(!rsTypes.IsEOF())
size=2>rsTypes.GetFieldValue(4,convdesc);
rsTypes.MoveNext();
catch
(CDBException *pe)
pe->Delete();
size=2>}
Hi, Joseph!
=========Beginning of the citation==============
If I want my reply to be in plainText, what do I need to do? Rob's
posting is in HTML, but I want my reply in plainText.
=========The end of the citation================
You can set Plain text in menu Format of Outlook Express.
Best Regards,
Alexander Rivilis
Thanx Alex,
to add, have to uncheck "Reply to messages using the format in which they
were sent".
Joseph
"Alexander Rivilis" wrote in message
news:6FD330B94ADEC1200A03F644391512F0@in.WebX.maYIadrTaRb...
> Hi, Joseph!
> Best Regards,
> Alexander Rivilis
