Missing ObjectARX AddIn Toolbar and Autodesk Class Explorer in Visual Studio 2022
furqananees2007
furqananees2007
I'm experiencing an issue with Visual Studio 2022 where I'm unable to find the ObjectARX AddIn toolbar. Despite successfully downloading, installing, and configuring the ObjectARX SDK 2024 and ObjectARX wizards 2024, the toolbar is nowhere to be found. I'm following a tutorial that requires me to use the Autodesk Class Explorer, which is typically accessible through the ObjectARX AddIn toolbar, to implement properties and base class methods. However, without the toolbar, I'm stuck. I have attached the document.
Is the ObjectARX AddIn toolbar compatible with Visual Studio 2022? Are there any specific steps or configurations I need to take to enable the toolbar? Are there alternative methods to access the Autodesk Class Explorer or achieve the same functionality without the toolbar? I'd appreciate any help or guidance on resolving this issue.
Thank you!
xym1139
Community Visitor
Community Visitor
Same problem ;(
eibnulkyes
Community Visitor
Community Visitor
