mirrored block == lose the xrecords
Message 1 of 9
I have this problem.
With my application I make some blocks and attach some xrecords.
If I make big block, from the original block and then mirror this, when I explode this big block I don't have any xrecord stored in the single sub blocks.
Instead of If I copy the big block and then I explode it, there are no problem, the xrecord are attached on sub block.
Any suggestions?
thanks in advance, andrea
Replies (8)
Message 2 of 9
Sub block?
What is a sub block?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:[email protected]...
Any suggestions?
Message 3 of 9
sorry,
nested block...
Message 4 of 9
Up!
Step to reproduce the error:
make a block, called block1
add to it xrecords
make a block, called block2
add to it xrecords
make a block with block1 and block2, called block3
mirror block3
explode mirrored block3
there are no xrecords on block1 and 2, remaining from the explosion of block3
help me please
tan You very much
Message 5 of 9
The xrecords are attached to the entities, the blockrefernce.
If you create a new blockdefinition , it contains "links" to the
blockdefinitions, not the original blocks
/Matt
Up!
add to it xrecords
add to it xrecords
mirror block3
block3
help me please
tan You very much
Message 6 of 9
hi,
if I copy the blockreference (with xrecords), also the xrecords are copied. (autocad copy itself the xrecords, this not true only for copying group)
If I copy the block3 instead of mirror it, when I explode the copy of block3 there are no problem: the xrecords are yet attached to block 1 e 2.
The problem is on the mirror command.
Any suggestion?
thank you very much.
Message 7 of 9
nested block or nested block reference?
sorry,
nested block...
Message 8 of 9
nested blockreference
my application:
create the blockreference1 and 2
attach to blockreference1 and 2 somo xrecords
then the user of autocad (using only autocad, not my application):
make a new block with blockreference 1 and 2, and called this for example block3.
Now
if the user (always in autocad) copy and then explode block 3, the remaing block reference 1 and 2 have the xrecord attached.
if the user mirror (with autocad mirror command) block3 and then explode it, on blockreference block 1 and 2 the xrecord are not present,
why this?
thank you very much
Message 9 of 9
sounds like a bug.
The nested block references are objects in
the definition of the mirrored block. When
a reference to that block is exploded, the
entities in its definition are deep cloned into
the space containing the reference that being
exploded. It's possible that the non-unform
scaling of the mirrored reference may have
something to do with it, but I don't see why
because AutoCAD doesn't place any grahical
meaning on XRecords.
You might try editing the mirrored reference
so it has a positive, uniform scale factor and
then explode that and see if the results are
the same.
my application:
Now
why this?
thank you very much
