< optimize code >Is there any way to speed up the excavation?
463017170
Message 1 of 11
463017170
static void MyGroupMyCommand () {
	ads_name en1;  ads_point p;
	Acad::ErrorStatus es;
	double L=100;
	double K=10;
	double Space =280;
	if (acedEntSel(L"\nSelect main ARC: ", en1, p) == RTNORM )
			AcDbObjectId id1, id2;
			acdbGetObjectId(id1, en1);
			AcDbObjectPointer<AcDbCurve> pEnt(id1, AcDb::kForWrite);
			if (pEnt.openStatus() == Acad::eOk ) {
				double startParam,endParam,startDist,endDist,dTmpParam1;
				AcGePoint3d startPoint,endPoint,TempPoint;
				AcGeVector3d zDir,xDir,yDir,nDir,mDir,lDir;
				AcGePoint3dArray pts1;
				es = pEnt->getStartParam(startParam);
				es = pEnt->getStartPoint(startPoint);
				es = pEnt->getEndPoint(endPoint);
				es = pEnt->getEndParam(endParam);
				es = pEnt->getFirstDeriv(startParam,zDir);
				es = pEnt->getDistAtParam(startParam, startDist);
				es = pEnt->getDistAtParam(endParam, endDist);
				AcGeMatrix3d curMat;
				pEnt->getEcs(curMat);
				yDir = AcGeVector3d(0,0,1).transformBy(curMat);
				xDir = yDir.crossProduct(zDir);
				AcGeMatrix3d transMat;
				xDir = xDir.normalize();
				yDir = yDir.normalize();
				zDir = zDir.normalize();
				transMat.setCoordSystem(startPoint,yDir,xDir,zDir);
				AcDbObjectPointer<AcDbPolyline> Orectangle;
				Orectangle.create();
				Orectangle->addVertexAt(0,AcGePoint2d(-L/2,K));
				Orectangle->addVertexAt(1,AcGePoint2d(+L/2,K));
				Orectangle->addVertexAt(2,AcGePoint2d(+L/2,0));
				Orectangle->addVertexAt(3,AcGePoint2d(-L/2,0));
				Orectangle->setClosed(Adesk::kTrue);
				Orectangle->transformBy(transMat);
				//PostToModelSpace(Orectangle);
				AcDbVoidPtrArray OArr,OgnArr;
				OArr.append(Orectangle);
				OgnArr.setPhysicalLength(1);
				es = AcDbRegion::createFromCurves(OArr,OgnArr);
				AcDbRegion *oRegion=AcDbRegion::cast((AcRxObject*)OgnArr[0]);
				AcDbObjectPointer<AcDb3dSolid> OSolid;
				OSolid.create();
				es = OSolid->extrudeAlongPath(oRegion,pEnt);
				oRegion->erase();
				OSolid->setColorIndex(4);
				AcDbObjectId OSolidId = PostToModelSpace(OSolid);
				double len= endDist - startDist;
				int nn =int (len / Space);
				double startlen= (len - nn* Space)* 0.5;
				TempPoint=startPoint;
				for (int k = 0; k < nn+1; k++)
					es = pEnt->getParamAtDist(startlen+(k * 300),dTmpParam1);
					es = pEnt->getPointAtParam(dTmpParam1,TempPoint);
					es = pEnt->getFirstDeriv(dTmpParam1,nDir);
					es = pEnt->getSecondDeriv(dTmpParam1,mDir);
					nDir = nDir.normalize();
					mDir = mDir.normalize();
					lDir = nDir.crossProduct(mDir);
					AcGeMatrix3d MtransMat;
					MtransMat.setCoordSystem(TempPoint,lDir,mDir*-1,nDir);
					AcGeMatrix3d mat;
					AcGeVector3d vec;
					AcDbObjectPointer<AcDb3dSolid> LsSolid1;LsSolid1.create();
					LsSolid1->createFrustum(K*4, 6, 6, 6);
					mat.setToRotation(1.5707963268,AcGeVector3d::kXAxis,AcGePoint3d::kOrigin);
					LsSolid1->transformBy(mat);
					vec = AcGeVector3d (L/2-10,0,0);
					mat.setToTranslation(vec);
					LsSolid1->transformBy(MtransMat);
					AcDbObjectPointer<AcDb3dSolid> LsSolid2;LsSolid2.create();
					LsSolid2->createFrustum(K*4, 6, 6, 6);
					LsSolid2->transformBy(mat);
					vec = AcGeVector3d (10-L/2,0,0);
					LsSolid2->transformBy(MtransMat);
					AcDbObjectPointer<AcDb3dSolid>OSolid(OSolidId,AcDb::kForWrite);
					OSolid->booleanOper(AcDb::kBoolSubtract,LsSolid1);
					assert(LsSolid1->isNull());LsSolid1->erase();LsSolid1->close();
					OSolid->booleanOper(AcDb::kBoolSubtract,LsSolid2);
					assert(LsSolid2->isNull());LsSolid2->erase();LsSolid2->close();
Replies (10)
Message 2 of 11
daniel_cadext
maybe use a transaction? Not sure if that would help
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 3 of 11
tbrammer
I have three suggestions to optimize. But they won't yield a considerable performance boost:
1.) Only open objects kForWrite if you really need to modify them:
AcDbObjectPointer<AcDbCurve> pEnt(id1, AcDb::kForRead); // Opening kForRead is enough
2.) You can move
AcDbObjectPointer<AcDb3dSolid> LsSolid1, LsSolid2; outside of the for loop:
AcDbObjectPointer<AcDb3dSolid> LsSolid1; LsSolid1.create();
AcDbObjectPointer<AcDb3dSolid> LsSolid2; LsSolid2.create(); // moved outside the for-loop
for (int k = 0; k < nn + 1; k++)
You don't append them to the database so you don't need to erase()and close() them.
// assert(LsSolid2->isNull()); LsSolid2->erase(); LsSolid2->close();
3.) If you want to apply three transformation matrices to an entity it is more efficient to calculate a final transformation matrix M=m3*m2*m1 and transform once with entity->transformBy(M) than transforming with m1,m2 and m3 individually:
LsSolid1->createFrustum(K * 4, 6, 6, 6);
mat.setToRotation(1.5707963268, AcGeVector3d::kXAxis, AcGePoint3d::kOrigin);
AcGeMatrix3d MatFinal = mat;	// Calculate a final transformation matrix
vec = AcGeVector3d(L / 2 - 10, 0, 0);
MatFinal = MtransMat * mat * MatFinal;
LsSolid1->transformBy(MatFinal); // and transform once with MatFinal
LsSolid2->createFrustum(K * 4, 6, 6, 6);
vec = AcGeVector3d(10 - L / 2, 0, 0);
LsSolid2->transformBy(MatFinal); // and transform once with MatFinal
Note: Your calculation of lDir, nDir, mDir is OK for arcs. But in general mDir is not perpendicular to nDir - i.e. if your curve is a spline. This calculation works as long as mDir is not null:
lDir.normalize();
mDir = nDir.crossProduct(lDir); // mDir is not always perpendicular to nDir!
nDir.normalize();
mDir.normalize();
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 4 of 11
463017170
booleanOper    This is slow
Message 5 of 11
tbrammer
Yes, booleanOper() is the call that takes the most time. But if you want a boolean subtraction to be performed on a 3DSOLID there is no alternative.
It might help to make sure that the cylinders that you subtract "clearly" pierce the surfaces of the 3DSOLID at both ends. So make them "long enough". If the ends of the cylinders are close to the bounding surface of the 3DSOLID the calculation might require greater accuracy internally.
If the region that you extrude along the path is always a rectangle sized X * Z you might try this:
  • Create an AcDbSweptSurface using sweeping just a line with length X along the path.
  • Subtract the cylinders with  AcDbSurface::booleanSubtract (AcDb3dSolid*, AcDbSurface*&)
    The cylinders should "clearly" pierce the surface. So make them "long enough".
  • Thicken the surface with AcDbSurface::thicken(Z,...).
This might run faster because the boolean operation involves less calculations for a surface than for a 3DSOLID.
Message 6 of 11
463017170
Do not understand, can write an example, thank you!
Message 7 of 11
tbrammer
Regarding my 1st suggestion: Looking at your code I see that you are already making the cylinders "long enough". The length K*4 makes sure that they pierce the solid, which is K thick. So just forget this one.
Regarding my 2nd suggestion:
Currently you create an AcDb3dSolid by extruding a rectangle and subtract cylinders from it.
My idea is to create an AcDbSweptSurface by sweeping a line, subtract the cylinder from it and finally create the AcDb3dSolid by thicken() the AcDbSweptSurface
Sample Code:
#include <dbsweptsurf.h>
void cmdOptimizeCommandSurf() {
	double L = 100;
	double K = 10;
	double Space = 280;
	if (acedEntSel(L"\nSelect main ARC: ", en1, p) == RTNORM)
		if (pEnt.openStatus() == Acad::eOk) {
			double startParam, endParam, startDist, endDist, dTmpParam1;
			AcGePoint3d startPoint, endPoint, TempPoint;
			AcGeVector3d zDir, xDir, yDir, nDir, mDir, lDir;
			es = pEnt->getFirstDeriv(startParam, zDir);
			yDir = AcGeVector3d(0, 0, 1).transformBy(curMat);
			transMat.setCoordSystem(startPoint, yDir, xDir, zDir);
			AcDbObjectPointer<AcDbPolyline> Oline;
			Oline.create();
			Oline->addVertexAt(0, AcGePoint2d(-L / 2, 0));
			Oline->addVertexAt(1, AcGePoint2d(+L / 2, 0));
			Oline->transformBy(transMat);
			AcDbSweptSurface *sweptSurface = new AcDbSweptSurface;
			AcDbSweepOptions sweepOptions;
			es = sweptSurface->createSweptSurface(Oline, pEnt, sweepOptions);
			AcDbSurface *surface = sweptSurface, *pNewSurface=nullptr;
			AcDbDatabase* pDB = acdbHostApplicationServices()->workingDatabase();
			double len = endDist - startDist;
			int nn = int(len / Space);
			double startlen = (len - nn * Space) * 0.5;
			TempPoint = startPoint;
			AcDbObjectPointer<AcDb3dSolid> LsSolid1; LsSolid1.create(); // moved outside the for-loop
				es = pEnt->getParamAtDist(startlen + (k * 300), dTmpParam1);
				es = pEnt->getPointAtParam(dTmpParam1, TempPoint);
				es = pEnt->getFirstDeriv(dTmpParam1, nDir);
				es = pEnt->getSecondDeriv(dTmpParam1, mDir);
				lDir.normalize();
				nDir.normalize();
				mDir.normalize();
				AcGeMatrix3d MtransMat, MatFinal;
				MtransMat.setCoordSystem(TempPoint, lDir, mDir * -1, nDir);
				AcGeMatrix3d mat;
				AcGeVector3d vec;
				es = surface->booleanSubtract(LsSolid1, pNewSurface);
				if (!es && pNewSurface) {
					delete surface;
					surface = pNewSurface;
					pNewSurface = nullptr;
				es = surface->booleanSubtract(LsSolid2, pNewSurface);
					delete surface;
			// Create the solid
			AcDb3dSolid* pSolid = nullptr;
			bool bBothSides = false;
			es = surface->thicken(K, bBothSides, pSolid);
			delete surface; surface = nullptr;
			AcDbObjectId OSolidId;
			if (!es)
				pSolid->setColorIndex(4);
				es = postToDb(pDB, pSolid, OSolidId);
Message 8 of 11
tbrammer
One more thing regarding your code sample:
I just noticed that you have two identically named object pointers OSolid: One outside of the for-loop and one inside:
AcDbObjectId OSolidId = PostToModelSpace(OSolid); // keep OSolid open here...
for (int k = 0; k < nn+1; k++) {
    AcDbObjectPointer<AcDb3dSolid> OSolid(OSolidId,AcDb::kForWrite); //...and remove this!
It would improve the performance to remove the OSolid object inside the loop and make sure that  PostToModelSpace(OSolid)does not close OSolid
This will simply keep the AcDb3dSolid open for write after it is posted to the model space instead of open/close it in each loop. The destructor of the outer OSolid will close the AcDb3dSolid as soon as it goes out of scope.
Message 9 of 11
463017170
 Thank you very much!
Message 10 of 11
463017170
How can this be calculated at one time
Message 11 of 11
tbrammer
What do you mean? The calculation of MatFinal?
This is matrix multiplication.
