Loading Arx
Loading Arx
Loading Arx
I'm migrating an application to 2007. I converted all the module. It is working fine in my machine. when I load this module to some other machine (does not have VS2005 & Object ARX). It is not loading.
Autocad giving error message that
"It is an invalid ARX file"
"AcRxDynamicLinker failed to load"
Here i am attaching my Module(i comment out some of the line).
what is wrong in my project? please help me,
Sankar M
Sankar:
Use Dependency Walker to see which dependent DLL is missing. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
wrote in message news:5554547@discussion.autodesk.com...
Sankar M
Hi!
This is fortunately no arx specific problem. Had the same thing
on my Vista-computer. Every project I build there could not be
run on other computers, with the same message as you get.
My solution:
Use dependency walker and check the DLLs/ARX files. If it
displays a message like "Side-by-Side configuration failure..."
you will find the solution in this forum:
http://channel9.msdn.com/ShowPost.aspx?PostID=23261
For me it helped to disable the Embed manifest tool as
mentioned in this forum.
Hope this helps!
Br
Markus
> Hi,
> Sankar M
It is working fine after uninstalling Service pack 1 of Visual Studio 2005. In SP1 of VS 2005 Embed manifest tool setting in our application is asking some updated dll version (MFC80U.DLL, MSVCP80.DLL & MSVCR80.DLL) of .Net FrameWorks 2.0.
If this updated version is not available in your client machine then your Arx will not load.
Thanks for Replay,
Sankar.M
Hi Sankar,
It got the same problem see this discussion group 2007-04-12
I turned off everything that possibly could have something to do with Embed
manifest in the properties compiler/linker options.
My app works fine on other Pc's with XP SP2 and without VS installed
HTH
Johannes
skrev i en meddelelse news:5558757@discussion.autodesk.com...
FrameWorks 2.0.
Arx will not load.
Thanks for Replay,
Sankar.M
