load custom cuix
load custom cuix
load custom cuix
when i close the dwg window ,the menu come to the autocad cuix .how to modify it to my own cuix file when the dwg is closed.Does somebody know it?
You should use your cuix file name with full path.
thanks for your suggestion ,but i have given the full path name. when i load my arxApp,my cuix can be loaded successfully,but when i close the dwg ,the menu disappear.捕获.PNGown.PNG
the first picture show what the appearance when i close the dwg window.the second show my cuix appearance.i just want to keep the second appearance when i close the dwg window.
