Is there another way to remove entities from selection set when user box select?
xiaozhihui1992
Observer Observer
xiaozhihui1992
Observer
Observer
void CMyAcEdSSGetFilter::ssgetAddFilter(int ssgetFlags, AcEdSelectionSetService& service,
	const AcDbObjectIdArray& selectionSet, const AcDbObjectIdArray& subSelectionSet)
	auto stampBeg = std::chrono::steady_clock::now();
	AcGeIntArray arr;
	//arr.setLogicalLength(subSelectionSet.length());
	for (auto i = 0; i < subSelectionSet.length(); i++)
		service.remove(i);
	//service.remove(arr);
	auto stampEnd = std::chrono::steady_clock::now();
	double time_second = std::chrono::duration<double>(stampEnd - stampBeg).count();
up code sample is worked. But from test case :remove all 260000 entities in Autocad2018 costs 15 second. It's NOT
acceptable.
Is there another way to remove entities by filters? like filter by AcRxClass?
daniel_cadext
have you tried acedSSDel? have a look at ArxDbgSelSet in ARXDBG
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
xiaozhihui1992
Observer
Observer
May be, I raise a conflict with this problem.
I am NOT use acedSSGet api or raise a command to lead user pick , but the
command in "Quiescent State" . There NO command running, then user pick.
I want to remove the entities before the entities put into the pick first selection set.
tbrammer
In your code
	service.remove(i);
you are calling AcEdSelectionSetService::remove(int index).
But there is also the method AcEdSelectionSetService::remove(const AcArray<int>& indices), which might be more performant. Try this:
AcArray<int> indices;
int count = subSelectionSet.length();
indices.setLogicalLength(count);
for (int i = 0; i < count; i++)
	indices[i] = i;
service.remove(indices);
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
xiaozhihui1992
Observer
Observer
Yes.
Test results:
remove (const AcArray& indices)
    Total entities: 264792
     remove costs: 15.5 sec
remove (int index)
    remove costs: 15.8 sec
Machine:
windows 10 profession 10.0.19045
cpu: Intel core i7-10700
memory:  16GB 2400MHZ
