Invoke a function after object rotation
Message 1 of 47
Hi to all,
I'd like to have a block that when The user rotate the block I can call automatically a custom function and print of how much degrees is rotated. Could you give me some examples or idea ?
Best Regards,
Marco
Replies (46)
Message 41 of 47
Alexander.Rivilis
@Anonymous wrote:
Hi @Alexander.Rivilis,
could you show me an online sample of if statement using acedGetCommandForDocument ?
Than you,
Marco
What about to read ObjectARX Documents?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 42 of 47
Thank you @Alexander.Rivilis , I appreciated very much your help. Sorry I'm not an Autocad developer, I'm Studing for my thesis ObjectArx. I didn't know that this guide was in the autocad folder.
You have been very kind and I thank you for helping me.
Marco
Message 43 of 47
Alexander.Rivilis
Marco
This guide is a part of ObjectARX SDK (docs folder):
Expert Elite Member
Message 44 of 47
Hi @Alexander.Rivilis ,
I've downloaded your code but the transformBy() function is not called anytime by AutoCAD. I tried a breakpoint on the function but the code execution never stop on this bp. I think that the code has no effect on my AutoCAD.
I'm attaching my code if you can help me.
P.S. thank you to @moogalm for the .bat script
Best Regards,
Marco
Message 45 of 47
Alexander.Rivilis
@Anonymous
Test attached code and see this video.
Expert Elite Member
Message 46 of 47
Hi @Alexander.Rivilis now it's working, thank you.
I'm trying to set an Xdata with the theta calculated by the matrix as you mentioned before.
static void setLayoutAttribute(AcDbEntity* pSubject,double theta) // brefCar must be open for write
	  AcDbObjectId objId = pSubject->objectId();
	  AcDbObjectPointer<AcDbBlockReference>  brefWheel(objId, AcDb::kForWrite);
	  if (brefWheel.openStatus() == Acad::eOk)
		  LPCWSTR myAppName = L"LAYOUT";
		  acdbRegApp(myAppName); // Make sure your XData appname is registered
		  resbuf *rb = acutBuildList(
			  AcDb::kDxfRegAppName, myAppName,
			  AcDb::kDxfXdReal, theta,
			  0
		  brefWheel->setXData(rb);
		  acutRelRb(rb); // release the list.
But calling this function from transorfmBy()  the blockreference is nevere in openStatus() == eOk.
 ACDBCORE2D_PORT virtual Acad::ErrorStatus transformBy(AcDbEntity* pSubject, const AcGeMatrix3d& xform)
    AcString pGlobalCmdName;
    acedGetCommandForDocument(curDoc(), pGlobalCmdName);
    acutPrintf(L"\nTransformBy Command name: %s", pGlobalCmdName.kTCharPtr());
	if (pGlobalCmdName.compareNoCase(L"ROTATE") == 0) {
		double theta;
		AcGeVector3d vectors;
		getAngleAndAxis(theta, vectors,xform);
		acutPrintf(L"Rotazione di : %f radianti", theta);
		setLayoutAttribute(pSubject, theta);
I'm missing something ?
B.R.
Marco
Message 47 of 47
Alexander.Rivilis
pSubject is opened before calling setLayoutAttribute(...) So you not need to open it again:
static void setLayoutAttribute(AcDbEntity* pSubject, double theta)
  bool wasWriteEnabled = pSubject->isWriteEnabled();
  if (wasWriteEnabled || pSubject->upgradeOpen() == Acad::eOk)
    resbuf* rb = acutBuildList(
      0
    pSubject->setXData(rb);
    if (!wasWriteEnabled) pSubject->downgradeOpen();
Expert Elite Member
