How to test grip funcionality in custom object in an objectARX app?
o.simeon81
o.simeon81
I have created an objectarx plugin with a custom entity and want to write a group of tests that will
actually test if movegrippointsat works as it should.
The tests should simulate the user's choice of the custom entity(ies), activation of grips, (dragging) and grip_stretching.
The purpose is to automate this testing in order for me not to do it manually each time I change something
in movegrippointsat.
Any idea (e.g. scripting, autolisp, objectARX) would be helpful.
Thank you in advance.
tbrammer
You could try to develop a "virtual user" with AutoHotkey. It is a powerfull free tool that allows to write or record scripts that can simulate keyboard input, mousemoves and -clicks.
Also you could write test code that directly calls some of your overridden methods like getGripPoints(..) / moveGripPointsAt(..) like AutoCAD would do. The problem is that you need to find out the correct sequence and which parameters you have to pass.
I haven't tried this myself to test grips - but this is what I would do.
Thomas Brammer ● Software Developer ● imos AG ● LinkedIn ●
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
