How to suppress user prompt during IAcadDocumentPtr::Export ?
cdnbake
cdnbake
Good morning,
In my ARX module for ACAD 2014-2017, I am trying to export the current view to an image file by using the method IAcadDocumentPtr::Export.
After creating a selection set, I call the function as follows:
IAcadDocumentPtr pActiveDoc;
/* determination of active document omitted */
IAcadSelectionSetsPtr pSelectionSets = NULL; pActiveDoc->get_SelectionSets(&pSelectionSets);
IAcadSelectionSetPtr pSelectionSet = NULL; _bstr_t bstrtSelectSetName(L"SelectAll"); hr = pSelectionSets->Add(bstrtSelectSetName, &pSelectionSet);
hr = pActiveDoc->Export(bstrThumbnailFullFileName, _T("bmp"), pSelectionSet);
hr = pSelectionSet->Delete();
(I omitted error handling and NULL checks in favour of readability.)
While executing pActiveDoc->Export, AutoCAD prompts me for a selection anyways: "Select objects or <all objects and viewports>:".
Do I need to suppress this user prompt explicitly?
If so, then why do I have to pass a selection set to the method in the first place?
I also read this article and tried
hr = pActiveDoc->get_ActiveSelectionSet(&pSelectionSet);
beforehand, but the result was the same.
It would be great if someone could help me with that.
Have a nice day,
Bettina
Bettina Kutsche
CIDEON
take the value perspective.
cdnbake
Hello everyone,
I got the export working without AutoCAD prompting for an object selection! Smiley Happy
I simply had to call the method Select() on my previously created SelectionSet:
_variant_t variantEmpty;
variantEmpty.vt = VT_ERROR;
variantEmpty.lVal = DISP_E_PARAMNOTFOUND;
HRESULT hr = pSelectionSet->Select(acSelectionSetAll, variantEmpty, variantEmpty, variantEmpty, variantEmpty);
Now after calling pActiveDoc->Export() a BMP-Image gets saved as desired.
Have a nice day,
Bettina
Bettina Kutsche
CIDEON
cdnbake
Update: I have to add a small note about the method IAcadSelectionSet::Select().
If you call it on an empty drawing with no objects in it, for example right after creating a new file, the selection set will be empty as well and the IAcadDocument::Export() method will prompt you for input again.
For this special case, I had to set up a timer which fires VK_RETURN into the AutoCAD console to simply confirm that I want to export the whole viewport.
// if selection set is empty send timed VK_RETURN
long lCount = 0;
hr = pSelectionSet->get_Count(&count);
if (lCount == 0)
  acedGetAcadFrame()->SetTimer( SEND_VK_RETURN_TO_COMMANDLINE_START, 500, NULL);
I know this is a bit error prone, since it completely relies on the windows hook finding the correct application window where it can post the key event just in time. Thus, if someone has a better solution in petto, I will happily change it. Smiley Happy
Have a nice day,
Bettina
Bettina Kutsche
CIDEON
