how to read shapenames
     a shx file in a dwg is an AcDbTextStyleTableRecord in dwg, is there any way to get all shape names in this shx file with AcDbTextStyleTableRecord, not read the binary file.
Alexander.Rivilis
static void ShapeNames(void)
  struct SHAPESTRUCT {
    unsigned short iShapeNumber;     // shape number
    unsigned short iDefBytes;        // number of data bytes in shape, 2000 max
    unsigned char *lpszShapeName;    // pointer to shapename
    unsigned char *lpszSpecBytes;    // pointer to shape specification bytes
  char SHAPE10[] = "AutoCAD-86 shapes 1.0";
  char SHAPE11[] = "AutoCAD-86 shapes 1.1";
  resbuf *rbfile = NULL;
  if (RTNORM == acedGetFileNavDialog("Select shape file","","shx","ShapeNames",0,&rbfile))
    FILE *fshx = fopen(rbfile->resval.rstring,"rb"); acutRelRb(rbfile);
    if (fshx) {
      char desc[32];
      fread (desc,sizeof(desc),1,fshx);
      if (!strstr(desc,SHAPE10) && !strstr(desc,SHAPE11)) {
        acutPrintf("\nIt is not shape file!");
        fclose(fshx);
        return;
      fseek (fshx, (long)0x1c, SEEK_SET);
      unsigned short iNumShapes = 0;
      fread (&iNumShapes, sizeof (iNumShapes), 1, fshx);
      SHAPESTRUCT *lpShapeList, *lpShape;
      lpShapeList = (SHAPESTRUCT *)calloc(iNumShapes, sizeof (*lpShapeList));
      for (int i=0; i < iNumShapes; i++) {
        lpShape = lpShapeList + i;
        fread(&(lpShape->iShapeNumber), sizeof (lpShape->iShapeNumber), 1, fshx);
        fread(&(lpShape->iDefBytes), sizeof (lpShape->iDefBytes), 1, fshx);
      if (lpShapeList->iShapeNumber != 0) { // it is shape file
        for (int i = 0; i < iNumShapes; i++) {
          lpShape->lpszShapeName = (unsigned char *)(malloc (lpShape->iDefBytes));
          fread (lpShape->lpszShapeName, sizeof (*lpShape->lpszShapeName), lpShape->iDefBytes, fshx);
          acutPrintf("\nShape N%d = %s", i, lpShape->lpszShapeName);
          free(lpShape->lpszShapeName);
      } else {
      free(lpShapeList);
      fclose(fshx);
This code was written 5 years ago (before UNICODE "revolution" in AutoCAD). That is why you have to rewrite this code using UNICODE.
Facebook | Twitter | LinkedIn
Expert Elite Member
Alexander.Rivilis
Sample code for ObjectARX SDK 2007...2012:
    typedef struct {
        Adesk::UInt16 iShapeNumber;     // shape number
        Adesk::UInt16 iDefBytes;        // number of data bytes in shape, 2000 max
        Adesk::UInt8  *lpszShapeName;    // pointer to shapename
        Adesk::UInt8  *lpszSpecBytes;    // pointer to shape specification bytes
    } SHAPESTRUCT;
    Adesk::UInt8  SHAPE10[] = "AutoCAD-86 shapes 1.0";
    Adesk::UInt8  SHAPE11[] = "AutoCAD-86 shapes 1.1";
    if (RTNORM == acedGetFileNavDialog(_T("Select shape file"),_T(""),_T("shx"),_T("ShapeNames"),0,&rbfile))
        FILE *fshx = _tfopen(rbfile->resval.rstring,_T("rb")); acutRelRb(rbfile);
        if (fshx) {
            Adesk::UInt8 desc[32];
            if (!strstr((char *)desc, (char *)SHAPE10) && !strstr((char *)desc, (char *)SHAPE11)) {
                acutPrintf(_T("\nIt is not shape file!"));
                fclose(fshx);
                return;
            Adesk::UInt16 iNumShapes = 0;
                    AcString sname = lpShape->lpszShapeName;
                    acutPrintf(_T("\nShape N%d = %s"), i, sname.kACharPtr());
            } else {
            free(lpShapeList);
            fclose(fshx);
Expert Elite Member
