how to read attribute block from autocad in vbnet?
I have my project in visual studio and i want read one attribute from my dwg block and after return and create new attribute in this block.
And other question i only load dll into autocad right, because i want run one external form.vb from autocad
Please help
Thanks for all
tbrammer
First: You should post VB quesions in the .NET or Visual Basic Customization forum.
@Anonymous wrote: i want read one attribute from my dwg block and after return and create new attribute in this block.
I suppose you want to read/add an attribute from a block reference in your DWG.
See docs for class BlockReference, Property AttributeCollection().
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Thank u i know now how do it
