How to obtain control or snap points for dynamic blocks?
xropro
xropro
As shown in the image, I want to obtain the two grips pointed by the arrows
tbrammer
To retrieve grip points you can call
Acad::ErrorStatus   AcDbEntity::getGripPoints(AcDbGripDataPtrArray& grips,
	const double curViewUnitSize, const int gripSize,
	const AcGeVector3d& curViewDir, const int bitflags
) const;
for the dynamic BREF.
Note that you must delete the AcDbGripData objects in the grips array.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
xropro
How can an Object ARX program obtain a MiniDump file when the program crashes? What is the purpose of the acedDisableDefaultARXExceptionHandler() function? Can you give me an example program to obtain MiniDump files? Thank you!
tbrammer
That's a new and completely different topic.
Can you please ask this in a new posting? This one is "solved".
So other attendants can find and reply to it.
