how to modify vertex of AcDb3dPolyline which is not in database
475867377
475867377
the pPolying is AcDb3dPolyline which is not in database.i want to modify its vertex like the follow picture,but it failed,return eNoDatabase error.i want to know how to modify the vertex.
tbrammer
Your are using the iterator wrong. Try this:
	AcDbObjectIterator *it = pPolying->vertexIterator();
	if (it)  {
		for (it->start(); !it->done(); it->step())	{
			AcDb3dPolylineVertex* pVertex = AcDb3dPolylineVertex::cast(it->entity());
			if (pVertex)
				es = pVertex->setPosition(pt);
				// Don't delete pVertex!
		delete it; // But delete the iterator when you are done with it
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
