How to implement AcGeMatrix3d::setToWorldToPlane(const AcGePlane& plane)
Hello, everyone!
I Have imp a Matrix3d of myself.The interface of it is very similar with AcGeMatrix3d,And I have imp a cmpare function to cmp them for testing the equality.
All other interface is done well. But I really don't know
     setToWorldToPlane(const AcGePlane& plane);
planeInput plane specifies a UCS whose origin is the origin of the plane, whose x-axis is the x-axis of the plane, etc.
How To imp it?
Thanks!
Balaji_Ram
The AcGeMatrix3d::setToPlaneToWorld determines the transformation required from the plane to the world. Here is a sample code snippet that uses the AcGeMatrix3d::alignCoordSys to determine the same matrix. I hope this helps you understand what the AcGeMatrix3d::setToPlaneToWorld does.
AcGePlane testPlane = AcGePlane::kZXPlane;
// Plane Origin, X axis, Y axis and Z axis
AcGePoint3d	fromOrigin;
AcGeVector3d fromXAxis;
AcGeVector3d fromYAxis;
testPlane.getCoordSystem(fromOrigin, fromXAxis, fromYAxis);
AcGeVector3d fromZAxis = testPlane.normal();
AcGeMatrix3d mat1 = AcGeMatrix3d::kIdentity;
mat1 = AcGeMatrix3d::alignCoordSys(	fromOrigin,
									fromXAxis,
									fromYAxis,
									fromZAxis,
									AcGePoint3d::kOrigin,
									AcGeVector3d::kXAxis,
									AcGeVector3d::kYAxis,
									AcGeVector3d::kZAxis
mat1 = mat1.inverse();
// Verify the matrix
AcGeMatrix3d mat2 = AcGeMatrix3d::kIdentity;
mat2 = AcGeMatrix3d::planeToWorld( testPlane );
if(mat1.isEqualTo(mat2))
	acutPrintf(ACRX_T("Results are the same !!"));
else
	acutPrintf(ACRX_T("Results differ !!"));
Balaji
Developer Technical Services
Autodesk Developer Network
