How to get the coordinates of the actual view corners
How do I get the coordinates of the actual view corners?
Thanks ...
View or viewport?
Aragao
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
How
View or viewport?
... viewport I think ... what I need are the corners of the actual drawing surface in the model space ...
thanks
Here:
void
color=#880000>sgGetCorner
size=2>()
//Get the VIEWCENTER(Centro da View)
in current UCS
//and transform the point to DCS
(Display Coordinate System
struct
resbuf
color=#808080>rbViewCtr
size=2>;
ads_point
ptCenter
size=2>;
if
color=#000000>((
acedGetVar
color=#000000>(
"VIEWCTR",
rbViewCtr)) !=
RTNORM)
color=#0000ff>return
ptCenter
color=#000000>[
X] =
rbViewCtr.
color=#808080>resval
color=#808080>rpoint
color=#a000a0>X
ptCenter
color=#000000>[
Y] =
rbViewCtr.
color=#a000a0>Y
ptCenter
color=#000000>[
Z] =
rbViewCtr.
color=#a000a0>Z
struct
resbuf
color=#808080>rbUCS
color=#808080>rbDCS
color=#808080>rbWCS
ads_point
ptCenterDCS
size=2>;
rbUCS
color=#000000>.
restype =
RTSHORT
size=2>;
rbUCS
color=#000000>.
resval
color=#000000>.
rint
color=#000000> = 1;
rbDCS
color=#000000>.
restype =
RTSHORT
size=2>;
rbDCS
color=#000000>.
resval
color=#000000>.
rint
color=#000000> = 2;
rbWCS
color=#000000>.
restype =
RTSHORT
size=2>;
rbWCS
color=#000000>.
resval
color=#000000>.
rint
color=#000000> = 0;
if
color=#000000>((
acedTrans
color=#000000>(
ptCenter,
rbUCS,
rbDCS, 0,
ptCenterDCS)) !=
RTNORM)
//Get the VIEWSIZE (in drawing
units),
//which is the height of the
view.
struct
resbuf
color=#808080>rbViewSize
size=2>;
double
dblHeight
size=2>;
if
color=#000000>((
acedGetVar
color=#000000>(
"VIEWSIZE",
rbViewSize)) !=
RTNORM)
dblHeight
rbViewSize.
color=#808080>rreal
//Get the screen aspect ratio using
SCREENSIZE system variable.
//Using the value returned by
SCREENSIZE, get the screen width
//and screen height. SCREENSIZE
returns a list of two reals,
//first one is the screen width and
second one is screen height.
struct
resbuf
color=#808080>rbScreenSize
size=2>;
double
dblWidth
size=2>;
if
color=#000000>((
acedGetVar
color=#000000>(
"SCREENSIZE"
color=#000000>, &
rbScreenSize
color=#000000>)) !=
RTNORM
color=#000000>)
return
color=#000000>;
dblWidth =
dblHeight*(
[0]
size=2>[1]);
//Calculate the lower left corner in
DCS
ads_point
ptMinDCS
size=2>;
ptMinDCS
color=#000000>[
X] =
ptCenterDCS[
color=#a000a0>X
color=#808080>dblWidth
2);
ptMinDCS
color=#000000>[
Y] =
ptCenterDCS[
color=#a000a0>Y
color=#808080>dblHeight
2);
ptMinDCS
color=#000000>[
Z
color=#000000>] = 0;
//Calculate the Upper right corner in
DCS
ads_point
ptMaxDCS
size=2>;
ptMaxDCS
color=#000000>[
X] =
ptCenterDCS[
color=#a000a0>X
2);
ptMaxDCS
color=#000000>[
Y] =
ptCenterDCS[
color=#a000a0>Y
2);
//Transform lower left and upper righ
corner
//from DCS to
WCS
ads_point
ptMinWCS,
color=#808080>ptMaxWCS
size=2>;
if
color=#000000>((
acedTrans
color=#000000>(
ptMinDCS,
rbDCS,
rbWCS, 0,
ptMinWCS)) !=
color=#a000a0>RTNORM
if
color=#000000>((
acedTrans
color=#000000>(
ptMaxDCS,
rbDCS,
rbWCS, 0,
ptMaxWCS)) !=
//Draw line from lower corner to
upper corner
createLine
color=#000000>(
ptMinWCS,
ptMaxWCS
size=2>);
return
size=2>;
CHeers,
Aragao
View
or viewport?
thanks
diagodose2009
Hi...
Here is my solution... in programming language virtualc+lisp for all CAD's platforms.........
I can convert the routine  "dfn_view_getpnts" to ObjectARx+Cpp but ,i need  your ... private message...
In autolisp,or c++arx my routine  work very nice
best regards..
