How to get Layer Name from a Block Table Record
chockalingam
chockalingam
   I have block table record, and now i want to find the layer in which the particular block is present.
   I am a newbie to ObjectARX, can any one help in this issue.
   Thanks in Advance.
Chockalingam
Alexander.Rivilis
   Thanks in Advance.
Chockalingam
And if there are some instances of AcDbBlockReference, which refer to a single instance of AcDbBlockTableRecord? Layer which of them you have to know?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
chockalingam
I need to know the layer of the blockreference
Alexander.Rivilis
If you have instance of class AcDbBlockReference - you can use his method layer() in order to have it's layer name.
Expert Elite Member
chockalingam
Can you guide me in getting blockreference from blocktable
Alexander.Rivilis
blockreference from blocktable??? Sorry but It is impossible. You have to study the structure dwg-file with ObjectARX SDK Documentation.
Expert Elite Member
chockalingam
Thanks for your support
