How to facet AcDbSubDMesh objects?
AcDbSubDMesh objects are produced by the MESH command in autocad 2010 upwards. I wonder if anyone can let me know how to get at the underlying geometry of the object, to produce an array of triangles or polygons representing the object?
Malcolm
Alexander.Rivilis
What about using method explode of class AcDbSubDMesh?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
I have just written a blog post that also might be of help:
http://adndevblog.typepad.com/autocad/2012/05/facet-subd-mesh.html
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
Ah
I think I can answer my own question.  There seem to be a couple of ways to go.  The first is pretty direct:
Given an AcDbEntity *pEnt pointer:
AcDbSubDMesh *pMesh=(AcDbSubDMesh *)pEnt;
AcGePoint3dArray vertexArray;
AcArray<Adesk::Int32> faceArray;
Acad::ErrorStatus es = pMesh->getFaceArray(faceArray);
if(es==Acad::eOk){
es=pMesh->getVertices(vertexArray);
And then walk through the faceArray and Vertex array to extract the geometry.  The above however doesn't do any smoothing, so that you end up with a large number of elements even for simple geometry.  For example, for a simple default cube, this gives 54 (or 56 can't quite remember) faces.  I don't know if someone has any suggestions on this.
In order to reduce the face count, all I can come up with is to go via a solid, and choosing the appropriate  bConvertAsSmooth and optimize flags:
AcDb3dSolid *pSolid=NULL;
pMesh->convertToSolid(false,true,pSolid);
if(pMesh!=NULL){
  AcDbFaceterSettings faceter;
  AcGiFaceData* faceData=NULL;
  Acad::ErrorStatus es=acdbGetObjectMesh(pSolid,&faceter,vertexArray,faceArray,faceData);
Going via a solid seems to be clumsy and so I'd be interested in any comments!
Adam
Thanks for that - very helpful - saw it just after I'd posted.
Can you offer anything on the smoothing/welding issue to reduce the face count for simple geometry?
Malcolm
